Author: Subject: Alarm / immobiliser and IVA
corrado vr6
posted on 13/9/13 at 07:12 PM Reply With Quote
Hi there,
I've just had my letter for confirmation of my IVA test in southampton through the post today, however at the bottom of the letter it says if there is an alarm / immobiliser fitted (which there is) then I must supply an original certificate of installation from an approved installer to show that it meets the European directive requirements.
However I have fitted it myself and I'm sure I read on here not so long ago that this rule was no longer and you could fit it yourself, am I wrong? And it just an old template letter?
If I have to get a certificate I will but I'm sure that I read that it was no longer an IVA requirement anymore
Can anyone confirm?
Cheers Greg
http://r1indy7.wordpress.com/
Sloan85
posted on 13/9/13 at 07:31 PM Reply With Quote
Had my iva in nottingham on 04/09/13. He took the immobiliser fob off the keyring to test it but didn't ask for any certificates.
http://mkindygsxr.blogspot.co.uk
Davegtst
posted on 13/9/13 at 07:35 PM Reply With Quote
I had my Iva this time last year and had the same thing about having a certificate. The tester didn't even check it worked at all.
corrado vr6
posted on 13/9/13 at 08:09 PM Reply With Quote
Okey doke, I know it's different at each centre but that sounds promising cheers chaps!
Dave Bailey
posted on 13/9/13 at 10:30 PM Reply With Quote
Don't worry I challenged this statement and basically the tester said no longer a requirement.... Basically he admitted we can build a car so to ask for a cert for installing a few wires was a little ridiculous.....
Dave B
corrado vr6
posted on 13/9/13 at 10:31 PM Reply With Quote
Lol great reply
Dave Bailey
posted on 13/9/13 at 11:20 PM Reply With Quote
By the way my iva was in Southampton about a month ago...
If you want me to share my experience let me know. ...
Dave B
corrado vr6
posted on 13/9/13 at 11:23 PM Reply With Quote
If its no trouble I would be grateful to hear how it went for you, either on here or via u2u
Cheers Greg
big-vee-twin
posted on 14/9/13 at 08:44 AM Reply With Quote
You can fit either a mechanical steering lock, as provided by the Sierra steering column, or if this is not present an electronic immobiliser must be fitted.
I guess if you have both they accept the mechanical device and ignor the immobiliser.
http://www.triangleltd.com
Dave Bailey
posted on 15/9/13 at 03:09 PM Reply With Quote
No problem.. Happy to have a call... U2u me your number......
Dave B
renetom
posted on 15/9/13 at 05:03 PM Reply With Quote
Hi
As far as I know its only the alarm that needs certification
We have a Toad immobiliser which does not need certification
The inspector did check it worked on our IVA
disable the alarm & you should be ok.
good luck
René
The Black Flash
posted on 16/9/13 at 10:37 PM Reply With Quote
Yep - definately used to say that you needed a cert for an immobiliser, but they changed it some years ago, so that you no longer do.
