Author: Subject: need Protech shock measure
zekill
posted on 17/9/13 at 06:00 AM Reply With Quote
Hi all,
I want to change my olds shocks to Protech 400 series bearings version but i'm not sure i have any clearance at chassis rails, top rockers and trailing arms.
can anyone tell me the radius at end for Protech shocks bearings version and bonded version if it is not the same ?
Protech shock
Protech shock
Fisher Fury with Phoenix bodywork, Blade 919cc
me!
posted on 17/9/13 at 06:27 AM Reply With Quote
I'm not sure of the measurements, but on my Stylus I had to put a hole saw through the top rocker to give clearance for the protechs. I had no issues at the rear, but not sure how similar Fury/Stylii are at the back. Mine are the bonded bush versions, and transformed the car!
MikeCapon
posted on 17/9/13 at 06:58 AM Reply With Quote
The rad is R18 on bearing and bonded bushes.
HTH Mike
www.shock-factory.co.uk
zekill
posted on 17/9/13 at 10:28 AM Reply With Quote
thank very much for measures, this help me
zekill
posted on 18/9/13 at 07:09 AM Reply With Quote
well, there no fit at front chassis rails and rockers arms, at rear on trailing arms too
MikeCapon
posted on 18/9/13 at 09:52 AM Reply With Quote
That is not necessarily a show stopper Zekill. The loops are well over engineered. To give you an idea, the bonded bush fittings are 7/8" OD and the bearings are 1". You can comfortably remove some material without any risk. My own shocks run a 26mm OD bearing and the rad is 17.5 with a further flat machined at R16.5 so the thickness left is just 3.5mm and those shocks run in some heavy duty applications with up 1800 lbf/in springs.
zekill
posted on 18/9/13 at 11:02 AM Reply With Quote
ok, thank for advice.
Camber Dave
posted on 19/9/13 at 09:03 AM Reply With Quote
On one I did some work on I drilled a 5/8 hole in the rocker and added a countersink below.
It give me plenty of room and the top eye cleared just fine
zekill
posted on 19/9/13 at 11:02 AM Reply With Quote
the bad thing is at front lower rail.
max radius at shock is R14, this leave a small 0.5mm gap.
If I remove material from Protech shocks, there is only 1,3mm material from top to bearing.
it's not safe.
