Author: Subject: MX5 parts
scutter
posted on 21/9/13 at 10:40 AM Reply With Quote
MX5 parts
Greetings Folks,
I'm after some MX5 bits for the next build. I'll be away until the end of the month, with cash ready next month. The bits I need are;
Instruments/clocks with plug and as much loom as poss.
MK1/2 steering column (upper and lower) with switch gear and ignition barrel/key, plus plugs and loom section.
Does anyone have any of the parts about, before I start on the breakers yards.
Regards Dan.
BigLee
posted on 21/9/13 at 12:46 PM Reply With Quote
It's worth pointing out that if you go mark 1 or 2, you have to stick with that choice. The column switches are different, therefore have different plugs on the loom. They also bolt onto the column differently, so you can't mix a mark 1 column with mark 2 switches or a mark 1 loom with mark 2 switches etc. That's not to say it cannot be done, but you'd be making life unnecessarily hard for yourself. Guess how I know this??!!
Lee
scutter
posted on 21/9/13 at 01:37 PM Reply With Quote
Cheers Lee. I waa hoping for a complete column to avoid that issue.
Atb Dan
skov
posted on 21/9/13 at 01:58 PM Reply With Quote
I've got a mk1 cluster you can have for postage and a small number of beer tokens.
Might still have the connectors, will have to have a rummage. Let me know if you're interested.
