Author: Subject: Cange oil seals MT75
Antas
posted on 23/9/13 at 07:59 PM Reply With Quote
Do anyone know how to take away the oil seals on MT 75 gearbox?
john-t5
posted on 24/9/13 at 07:37 AM Reply With Quote
The rear seal is simple, remove the propshaft flange, think its a 30mm nut & pull the seal out, tap new one into place. The front seal inside the bell housing requires a special socket. As it's behind the release bearing carrier. Hope this helps.
Cheers John
Antas
posted on 24/9/13 at 09:12 AM Reply With Quote
Thank You, IŽll give it a try.
