Author: Subject: 1600 beetle engine
tomblyth
posted on 30/9/13 at 12:32 PM Reply With Quote
1600 beetle engine
Anyone got a beetle engine? 1600 if possible but would consider any, cheers
Mr Whippy
posted on 30/9/13 at 01:35 PM Reply With Quote
Stay away from the 1200 they can't be increased in capacity like the 1300 and are often offered very cheaply due to that.
To change from 1300 to 1600 requires new barrels, pistions and cylinder heads as it's the same stroke just a larger bore
Simon
posted on 30/9/13 at 10:02 PM Reply With Quote
But then if you're going to change a 1300 to a 1600, you may as well do a 1776 or 1835
Also, the 1200 was only a single port, the 13/1600 were twin port.
Simon
[Edited on 30/9/13 by Simon]
Mr Whippy
posted on 30/9/13 at 11:28 PM Reply With Quote
Simon
Beyond 1600 you then need longer throw cranks and machining to the inside of the case to make it all fit, the 1600 is the easy option. By the time you add up all the extra cost of beyond 1600 you might as well have started with a second hand Subaru engine and got some real power
