Author: Subject: Can anyone identify my camshaft?
bumpy
posted on 7/10/13 at 08:10 PM Reply With Quote
The camshaft in my 2 litre Pinto is marked as Ford H49 90E287.
I have checked the number with the local Ford dealer and he can find no record of it. The guy who built the engine some 12 years ago only remembered it as a mild GT cam.
Can anyone identify it?
Mr Whippy
posted on 7/10/13 at 09:47 PM Reply With Quote
Sorry for being pessimistic but there is no way a ford dealer will have part numbers for a 1980's engine. I suspect all the microfiches would have been binned by now. Even 1990 cars are a waste of time going to dealers.
I'd suggest trying to find out what the cam lobe heights are for different cam types and comparing it against them. Burton power might be able to provide that.
bumpy
posted on 7/10/13 at 11:01 PM Reply With Quote
They did have Sierra and Granada stuff, but not Cortina or Capri. I wonder if there is somewhere like Ford Central Office that would know more.
Unless of course I strike lucky on here. There must have been more than one of these sold.
Volvorsport
posted on 7/10/13 at 11:50 PM Reply With Quote
is it an RS2000 cam ?
as an aside , i can go into a volvo dealer with my 1979 volvo 242 and order parts for it .
www.dbsmotorsport.co.uk
getting dirty under a bus
snapper
posted on 8/10/13 at 05:38 AM Reply With Quote
RS2000 cam was standard
Only other cams Ford did was for Group 1 homologation
Normally cams have numbers and letters stamped in the cam rear end
I have not seen those numbers and if there cast in the shaft they done mean much
I eat to survive
I drink to forget
mark chandler
posted on 8/10/13 at 07:38 AM Reply With Quote
Probably just a batch number for the cam blank, you need to measure the duration and lift to work out what you have.
The standard cam is actually very good when timed in accurately, you need it advanced by around 5 - 7 degrees for most mid end punch.
Regards Mark
bumpy
posted on 9/10/13 at 09:53 AM Reply With Quote
Regards Mark
If it helps here is a piccy of the end number. The H49 is a casting number on the shaft and as suggested cam be ignored.
Does this look like a ford part number - there are cerainly some fainter inscribed markings as well which read ST.1 (Stage One?)
Is there a reference somewhere as to how one can measure the cam duration and lift?
[Edited on 9/10/13 by bumpy]
bumpy
posted on 9/10/13 at 03:39 PM Reply With Quote
Look to have drawn a complete blank on this having tried Burtons, Kent and Piper so will just put it back in and enjoy it.
