Author: Subject: Single throttle body sizes
Chaz
posted on 20/10/13 at 01:07 PM Reply With Quote
Does anyone have a list of the common single throttle body sizes? I'm looking for 48-52mm.
The application is for a zetec with plenum for eaton M45 supercharger.
Something which is used to handling boost will help too!
iank
posted on 20/10/13 at 04:48 PM Reply With Quote
MGF Trophy (the 160bhp version) has a 52mm body.
This one -> eBay Item
Rover 75 turbo used this one eBay Item but don't know what size it is.
Anonymous
lsdweb
posted on 20/10/13 at 05:25 PM Reply With Quote
Usually 48mm on MGZR etc. The plastic ones are rumoured to deform and stick (not sure how true that is).
Wyn
mark chandler
posted on 20/10/13 at 05:32 PM Reply With Quote
I would have a measure up on the eaton charger first and work out how large you need.
My m90 inlet is far smaller than the butterfly in the throttle body even after porting it out, if it's a gen3 charger you will definitely want to do this!
Regards Mark
snakebelly
posted on 20/10/13 at 05:56 PM Reply With Quote
For our supercharged GTA project we bought both a plenum and throttle body from IK Engineering, very helpful and reasonably priced.
HTH
Bare
posted on 20/10/13 at 10:58 PM Reply With Quote
Saab :-) Throttle body... a very simple unit, proven to well over 25psi. Almost free to buy at a breakers as well
posted on 21/10/13 at 04:09 AM Reply With Quote
Wyn
No rumour about it.
Plastic ones were only designed to have the inlet held on with a plastic hose clip, using a Jubilee or T Bolt hose clip crushes the throttle body and causes the throttle to stick.
I have a spare 48mm alloy one in the garage also a very large Ford CVH throttle body .
BaileyPerformance
posted on 21/10/13 at 07:57 AM Reply With Quote
Are you blowing thru the throttle or suck?
If your blowing thru just use the stock plastic zetec plenum and plastic throttle body, we have used these at 20psi several times without an issue. The throttle busy only deforms if you over tighten the hose clip.
If you suck thru (throttle on intake of blower) the plastic zetec one will also be fine.
Note the 2.0L zetec throttle is bigger than 1.8L
sebastiaan
posted on 21/10/13 at 06:06 PM Reply With Quote
Useful post, thanks!
lsdweb
posted on 21/10/13 at 07:18 PM Reply With Quote
No rumour about it.
Thanks BT - good to hear it from a reputable source on a reliable forum!
Chaz
posted on 21/10/13 at 08:05 PM Reply With Quote
Ok I'll have a look at the Rover 75 and MGF ones.
Of note I dont have space to use the original inlet and plenum, so i will have to get something custom put together.
I am blowing into the throttle body (after intercooling)
Thanks for all of your responses, helpful.
Just as a backup - any more throttle bodies between 48-52mm?
posted on 21/10/13 at 08:58 PM Reply With Quote
I'll post jpegs of the throttlebodies I have.
Another the throttlebody that might suit is the Honda PGFI one --- as used on 1990s Accords and Rover 600s
Chaz
posted on 22/10/13 at 07:35 PM Reply With Quote
Have you got some throttle bodies for sale?
Volvorsport
posted on 22/10/13 at 09:23 PM Reply With Quote
volvo 740/940...
3 bolt flange.
www.dbsmotorsport.co.uk
getting dirty under a bus
posted on 24/10/13 at 07:29 AM Reply With Quote
A Rover 48mm and Ford Xr3 CVH EFI throttlebody on upper manifold
Rear of Rover throttlebody
[Edited on 24/10/13 by britishtrident]
