Author: Subject: Part number help required
piddy
posted on 20/10/13 at 02:55 PM Reply With Quote
Hello all.
I’m looking for the part numbers of the following if any of you have or know a way of finding them out.
Brake servo Gasket and the gasket for the bulkhead panel that supports the brake servo.
These are on a 2005 Vauxhall Corsa or would I be better to just got o a local Vauxhall dealer?
The reason before anyone asks is water is leaking into the driver side passenger foot well of my sons car I’ve taken a good look and the only place I can see that it is getting in is through one of these seals, if not both.
Any help advice greatly received.
pewe
posted on 20/10/13 at 03:17 PM Reply With Quote
If it's only stopping water ingress then virtually any silicone sealant should be up to the job - QED.
Cheers, Pewe10
Ben_Copeland
posted on 20/10/13 at 03:25 PM Reply With Quote
You sure it's not the heater matrix leaking?
Ben
Locost Map on Google Maps
Enter Your Details Here
posted on 20/10/13 at 03:27 PM Reply With Quote
As above --- but unlikely to be the source the first thing I would do is check the scuttle drains are clear.
If it has a sunroof or AC also check the drains for those.
piddy
posted on 22/10/13 at 03:41 PM Reply With Quote
Hello.
Thanks for the replies.
I have checked the bulkhead drains they are clear.
I will check the heater matrix and AC drain.
It is a common problem with Corsa's leaking around the servo support panel, and water seems to be present on the foot pedals.
ian locostzx9rc2
posted on 22/10/13 at 05:49 PM Reply With Quote
The gasket is just silcone sealant its a big job to do steering column and pedal box out takes about 5 to 6hrs check the scuttle drains are clear first...
piddy
posted on 16/11/13 at 12:18 PM Reply With Quote
how do I check the AC drain?
