Author: Subject: Track day wet tyres????????
unijacko67
posted on 23/10/13 at 07:45 PM Reply With Quote
Hello everyone,
I've just picked a cheap set of alloys up for my reliant kitten with the intention of fitting a new set of (recommended) toyo proxes T1r's for wet track day use.
Two of the tyres already fitted with about 2-3mm tread left are Avon Turbospeeds CR28's. Any good in wet????
Two of the tyres already fitted with about 7mm tread left are Nankang EX500's. Any good in wet also????
I've searched reviews and it appears Turbospeeds might be ok in wet, but not sure about the Nankangs.
I struggled in the wet with rear grip with Medium ao48's, but the front didn't understeer or lock and turned in great (mind I was only going like a snail with cramp) so thought I might stick the Nankangs EX500 on the front and the Avons CR28 on the rear.
Do I try them or get a fresh set. If so what to get. Cheers
http://www.kittenkitcar.co.uk
snakebelly
posted on 23/10/13 at 08:22 PM Reply With Quote
In my limited experience of them i can best describe the Nangkangs as ditchfinders!
daniel mason
posted on 23/10/13 at 08:31 PM Reply With Quote
stick the nakangs on the front then jacko! you definately wont understeer into a ditch and the chances are if you do find a ditch you will almost certainly go into it backwards!
[Edited on 23/10/13 by daniel mason]
unijacko67
posted on 23/10/13 at 08:33 PM Reply With Quote
Yeah, I suppose I need a better wet tyre than Medium ao48's, at least for the rear anyway.
unijacko67
posted on 23/10/13 at 08:35 PM Reply With Quote
Come on Dan, stop fooling around, I'm trying to do it "Locost". I will catch you one day.
daniel mason
posted on 23/10/13 at 08:47 PM Reply With Quote
stick the avons on the back,wait for rain. truck haven roundabout, test them out! always slippy there.
think i need to catch you mate!
loggyboy
posted on 23/10/13 at 08:57 PM Reply With Quote
Rainsports are good budget wet, but sadly arent great in dry or mildly moist conditions.
Mistral Motorsport
unijacko67
posted on 23/10/13 at 09:04 PM Reply With Quote
I've got mi ao48 for if its a bit damp and some avon slicks for dry, but just need to know what to do about the potential wet track day tyre wise.
bi22le
posted on 23/10/13 at 10:39 PM Reply With Quote
Just go for some good quality straigt road tyre where heat is not a problem?
You did not mention size but mabe top bridgestone or top mich or top conti?
Please read my ring story:
jeffw
posted on 24/10/13 at 05:42 AM Reply With Quote
CR28 - Sports are great wet weather tyre, just make sure that is what you have as CR28 Sport and Turbospeed CR28 are not the same.
http://www.avonmotorsport.com/road-legal/performance/cr28-sport
Other alternatives are CR500 Avons or 021 Yokohama.
unijacko67
posted on 24/10/13 at 12:30 PM Reply With Quote
Cheers Jeff, good call on the turbospeeds, don't think they have sport on them so will bin them. Thanks for the Tyre choice advice. Cheers
unijacko67
posted on 24/10/13 at 05:57 PM Reply With Quote
Looking on-line the Rainsports and T1-R's are a good budget price, but are the CR 28 Sports a good bit better?
I've spoke to BMTR and they seriously recommend the CR 28 Sport tyre as you Jeff for the wet and good for short hill climbs, but £89.50 each plus vat and post. I'm gonna get a right bollocking of her in doors if I buy 4 of those bad boys.
At the end of the day if I don't have the right tyres for the track day "wet" conditions then that's also a total waste of time and money. I had to put the Kitten back on the trailer at dinner time last Blyton after being probably the slowest car on track, I quite like sliding about, but didn't fancy loosing it on the fast straights as it was very twitchy.
caroline89
posted on 22/11/13 at 09:32 AM Reply With Quote
Rain sports are exceptional plan wet, however unfortunately aren't extraordinary in dry or gently damp conditions.
Truck driving jobs
Matt21
posted on 28/11/13 at 07:46 AM Reply With Quote
I had a 306 gti6 and when i first got it i used toyo t1r's and thought it was great in the dry and still pretty good min the wet
I then bought a set of rainsport 2's.... they were just as grippy as the toyos in the dry and when it rained they remained just as grippy! from then on thats all i ever used on it
as soon as i find a spare set of alloys for my mk ill be sticking a set of them on
very highly rated by me, especially at the price!
Norfolkluegojnr
posted on 28/11/13 at 08:55 AM Reply With Quote
T1R's were our choice for damp greasy conditions at a sprint at Hethel a year or two back .... Never again.
Spent most of the time sideways. Excellent viewing for the marshals, not so good for my times. The R888's we used after performed much better in the damp, probably due to the quick heat build up.
I'm go with Rainsports, that's what we'll be using on the Clio next year for wet weather.
