Author: Subject: Tin top - Running noise "Chh Chh Chh"
MP3C
posted on 29/10/13 at 03:03 PM Reply With Quote
Hi guys,
The problem is there is a noise coming from the (i assume) rear end of my car. The noise is a "chh" sound; imagine a stone in your tire but with the "tick" sound a "chh" and when I increase my speed it gets faster until eventually I can't hear it (assuming other road noises take over). I think it's more noticeable when the car is cold rather than when it has been run a while.
Thought I would ask you guys if you know what it is before I jump to the conclusion of a rear wheel bearing needs replacing or something.
P.S the car is a MG ZR 105 Facelift if that helps.
Its done 65000 miles and the service history doesn't show the bearings being changed. Don't know the life expectancy really.
Cheers in advance,
Matt
Davey D
posted on 29/10/13 at 03:27 PM Reply With Quote
just jack up the rear of your car, and try pushing/pulling your wheels to see if there is any movement
CRAIGR
Contributor
Posts 2751
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 29/10/13 at 03:42 PM Reply With Quote
Do you get a "woo woo" every now and again ??
If so pull over immediately theres a steam train trying to overtake you
posted on 29/10/13 at 04:11 PM Reply With Quote
They are very prone to noise from the rear brakes for the first few hundred yards especially on the first run of the day. A clean out of the rear drums may help but it isn't a major issue.
ReMan
posted on 29/10/13 at 04:34 PM Reply With Quote
Souns like rear brakes to me. Mrs Yaris does it all the time, more so now the pads are a bit low
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
MP3C
posted on 29/10/13 at 04:38 PM Reply With Quote
I will have a quick look tonight when I get home I'll check for wobble and have a look see if there is build up of dust. thanks for the advice
Matt
davidimurray
posted on 29/10/13 at 04:46 PM Reply With Quote
If you have 17" "straights" on the car the wheel is very close to the shock. Check that the spring is seated correctly. Doubt it's related, but the heat shields are cr*p and can rattle like hell. Also check the exhaust mounts as a broken rubber can make the pipe rub against the rear suspension arm.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Davegtst
posted on 29/10/13 at 04:56 PM Reply With Quote
Doesn't sound too bad. When it starts going icky-icky-icky-icky-ptang-zhoo pang then you have a problem.
MakeEverything
posted on 29/10/13 at 05:26 PM Reply With Quote
Lol
Kindest Regards,
Richard.
snakebelly
posted on 29/10/13 at 05:54 PM Reply With Quote
don't rule out a cracked exhaust manifold, I once spent hours looking for a brake issue on the wifes MGF to only eventually discover is was a small crack in the manifold !
posted on 29/10/13 at 06:49 PM Reply With Quote
Especially if it previously made a "ni" sound
MP3C
posted on 29/10/13 at 07:50 PM Reply With Quote
Hahahaha!!!! hopefully will not get to that stage or I wont be able to work for my pennies!!
Can't be the exhaust manifold as while I was rolling down the road I switched the engine off and still had the same noise (obviously turned the engine back on pretty quick ) Also didn't get a chance to check tonight, don't know where my jack is :S
Matt
