Author: Subject: WTD - plastic pipe 200mm dia or more
mcerd1
posted on 13/11/13 at 11:36 AM Reply With Quote
as part of the on going 'get the house sorted for the new arrival' project I'm needing some large diameter pipe
it needs to be ~200mm dia or bigger, but I only need ~10 to 15 short lengths (say about 250 - 300mm long)
doesn't even have to be plastic as long as its cheap !
any suggestions ?
AndyGT
posted on 13/11/13 at 01:05 PM Reply With Quote
200mm sewerage pipe might do. Can't be too expensive neither.
Intrigued! What is it for?
andy
nothing is impossible
everything is possible
bi22le
posted on 13/11/13 at 01:55 PM Reply With Quote
I brought some 10" dia pipe for a test rig at work. I needed about 4m and it cost a fortune.
Maybe try a builders merchant and try to get their offcuts.
Please read my ring story:
iank
posted on 13/11/13 at 04:19 PM Reply With Quote
If thick cardboard is ok then you can get concrete column formers cheaply from bigger building suppliers.
Anonymous
trextr7monkey
posted on 13/11/13 at 06:37 PM Reply With Quote
we successfully blagged about 4' of 10" gas pipe and made 2 Santas post boxes from it by wrapping in red vinyl etc,
worth a go at your local utilities depot
good luck, Mike
mcerd1
posted on 19/11/13 at 10:20 AM Reply With Quote
yeah thats what I'm finding - if you want 4" pipe its no problem, anything bigger you need to buy big quantities
owelly
posted on 19/11/13 at 12:36 PM Reply With Quote
Steel any good? Plenty of heavy gauge steam pipe in that sort of size that should be available as offcuts at scrap prices. Or if thinner stuff is needed, get any local engineering firm to roll you some bits for beer money.
How about plastic gas main pipe? There's tons of the stuff rolling about along the roadside where I live!
http://www.ppcmag.co.uk
