Author: Subject: Front brake noise...
Dave Bailey
posted on 13/11/13 at 09:08 PM Reply With Quote
Pretty sure I know the answer but thought I would check... I have drilled and grooved front disks and when I press the brake pedal the pads seem to make a noise which based on the machining on the disc is probably expected.... Am I to be concerned?
Dave B
adithorp
posted on 13/11/13 at 09:35 PM Reply With Quote
A description of the noise might help...
http://jpsc.org.uk/forum/
Dave Bailey
posted on 13/11/13 at 10:16 PM Reply With Quote
Difficult to explain... pads on a smooth disc make no noise... It sounds like a cyclic ticking noise but only when the pedal is pressed. I suspect it is where the pads are transitioning over the grooves in the disc....
Dave B
pekwah1
posted on 13/11/13 at 10:22 PM Reply With Quote
i believe this is just the drilled discs, mine do the same...
google "woodpecker brakes"
AndyGT
posted on 13/11/13 at 11:34 PM Reply With Quote
On my classic I usually put pads in with a tad of copper slip grease on where the edge of the bad makes contact with the caliper. Not recommended on cars with ABS but it does stop the chattering noises from pads in calipers and less chance of pads seizing in too....
nothing is impossible
everything is possible
ashg
posted on 14/11/13 at 01:28 PM Reply With Quote
normal noise caused by the groves, if you don't want the noise go for solid or drilled only next time.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
