Author: Subject: Wanted
ed1max
posted on 18/12/13 at 09:52 PM Reply With Quote
Wanted
Just sold my Narrow body Westfield.
I am looking to replace it.Is there a kitcar that is as narrow as the Westfield but with more generous seat space as SWMBO doesnt fit anymore.
Gratefull for any help,apart from the obvious ....divorce!
posted on 18/12/13 at 11:22 PM Reply With Quote
EH? Why did you sell it if you want a one the same!
ed1max
posted on 18/12/13 at 11:25 PM Reply With Quote
Read my post I want one with the same wheebase but wider seats if possible which is not the same
l
Nickp
posted on 19/12/13 at 05:39 AM Reply With Quote
Best not to mention either of the D words, divorce or diet
Surely the only real option is a slightly wider chassis? ie a wide bodied (SEW, SEiW) Westfield, Haynes etc etc I'm sure there are many other more generous chassis that people can suggest. Probably best for you (and her) to sit in a few at the next show maybe?
BTW- I'm 16st/6ft+ and can drive a narrow Westy but wouldn't want to go 'touring' in one, it's a tad snug for proper sized folk!!
[Edited on 19/12/13 by Nickp]
snapper
posted on 19/12/13 at 06:50 AM Reply With Quote
McSorely does plans where you can choose width and lengths
You could keep length/wheel base but increase width
I eat to survive
I drink to forget
ed1max
posted on 19/12/13 at 10:00 AM Reply With Quote
Thanks for the advice boys
ashg
posted on 19/12/13 at 12:11 PM Reply With Quote
leave her at home
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
baz-R
posted on 20/12/13 at 10:29 PM Reply With Quote
even better get a single seater
austin man
posted on 21/12/13 at 12:53 AM Reply With Quote
seems contradictory in terms the same wheel base but wider seats, the body width generally defines the wheel base for example the MScorley is wider than an MK which is wider than a Caterham. most kits that use the Sierra running gear and drivetrain should be wider you also need to consider the seats being used. A fibreglass seat gives less room than a seat squab
