82 Locost
| posted on 18/12/13 at 10:08 PM |
Crossflow bits, racing suit, helmet, Westfield bonnet
COLLECTION FROM SALISBURY, WILTS (SP4 6BH)
Kent Cams BCF3 camshaft I think this is the biggest lift/duration you can get without having to machine the cylinder head. Hasn't been
used that much. There is a light water mark on the end journal (the non-drive end) but it only covers 1/3 of the width and would probably polish out.
£20 collected (can post at cost)
AE Oil pump Been used, but not for long. Kept as a spare for racing. £10 collected (can post at cost)
1300cc oil pick-ups (3 of) - £5 each collected
Timing cover (731M6059AA) includes new oil seal - £8 collected
1300cc sump - good condition with sump plug, gasket face flat £20 collected
Radiator - Brand new , but with storage marks. This was kept as a spare that I never got round to using. Has a screw cap and overflow and
modified inlet/outlet pipes (90 degrees off) £20 collected
Coilover springs , all 8" long and 1.9" inner diameter
2x300lb - £10
2x180lb - £10 per pair
3x400lb (yes 3, but 3 for the price of 2) - £10
Yellow genuine Westfield pre-litigation bonnet
Dimensions:
Length 99cm
Width at rear: 96.5cm
Drop at rear: 18cm
Width at front: 70cm
Drop at front: 16.5cm
Overall good condition, but with some minor damage, most notably at the front corners. Paint in good condition. £30.
Fire Extinguisher and mounting bracket
Will need to be re-filled. Or, can be used as a weapon next time you get cut up by a muppet in a Volvo. The gauge appears to show it holds pressure
well.
£make me an offer, but obviously not a massive one.
K&N Filter Care Service Kit - used once so nearly full. £3 collected
DGAV 32/26 carb in poor condition but could be useful for spares or a rebuild project. Not all there! I also have some jets and other bits.
£10.
I also have loads of little parts, like valves, head bolts, push rods, gaskets etc that it's too difficult to list individually. If you're
after something I might have one.
Momo Race suit: 2004 MOMO Nomex race suit. Size Medium (54) I'm 5'9" and a 40" chest and fitted me fine at both 11 and
13 stone , but would fit taller/shorter and fatter/thinner. Overall very good condition with a couple of minor issues (see below and pics). The
elasticated sleeves are still stretchy and it has always been stored out of sunlight so it hasn't faded. It's a bit dirty in places ubt it
works, and it's legal and cheap.
Meets current Blue Book requirement for a race suit (Standard 8856 2000).
There is a little wear to the stitching over the right hand pocket (caused by harness straps). There is also a small patch on the seat (approx
2" by 1" ) where there was a small tear. I had the suit patched by a seamstress in the same nomex material in the same colour with the
same stitching so it barely shows.
£85 incl postage
Helmet: Sparco Formula Full Face helmet. Small (but feels like a medium) Very good condition overall with a couple of very small stone chips
and a 1" long (cosmetic and non structural) surface 'crack' at the bottom of the visor opening. Could do with a new visor if
you're picky; I'm not picky and I was happy with the current one. Size small. I have a 57cm head (medium) and it fit me perfectly.
It's just like
THIS ONE ON
EBAY. Selling because I've given up racing otherwise I'd have happily kept using it and it always passed scrutineering.
£90 including postage and a protective case.
I've also got various parts from a low mileage Ford V6 Cologne engine. 6xpistons, crank, heads and various other bits. Let me know if
you're interested in any of these heavy legacy parts
anthony may
| posted on 21/12/13 at 12:16 PM |
westfield bonnet
hi there ,
i am interested in bonnet if you still have it , not too far from you so can collect no problem
many thanks ant .
82 Locost
| posted on 21/12/13 at 04:28 PM |
Hi Antony
PM sent
