Author: Subject: Fia kill switch on the negative side ?
steve m
posted on 26/12/13 at 11:33 AM Reply With Quote
One of my winter mods is to tidy up under the bonnet, and having done so, I know need to wire in my Fia kill switch, as per
http://www.ebay.co.uk/itm/Master-Battery-Isolator-Cut-Out-Off-Switch-FIA-Type-Kit-Car-Race-Rally-/261080914202?pt=UK_CarsParts_Vehicles_CarParts_SM&am p;hash=item3cc9a2991a
I have two options, either quite long positive wires, which I am trying to avoid, or just wire it up directly on the negative side,
and only using very short wires,
Question is, is it ok on the neg side?
mookaloid
posted on 26/12/13 at 12:04 PM Reply With Quote
I do believe that they are more effective on the +ve side
theconrodkid
posted on 26/12/13 at 12:25 PM Reply With Quote
from memory,it has to go on the + side as the resistor goes to earth and lets the alternator down so the engine wont keep on running if the handle is pulled from the outside
who cares who wins
pass the pork pies
Dave Bailey
posted on 26/12/13 at 01:06 PM Reply With Quote
And the resistor protects the diode pack I believe....
Dave B
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 26/12/13 at 02:08 PM Reply With Quote
I run a single seater without any charging system and have the kill switch on the negative (earth) lead . The earth lead must be marked with YELLOW tape.
bob
posted on 26/12/13 at 02:10 PM Reply With Quote
Ahhh so thats why my engine still runs when i pull the key LOL.
Actually mine was never intended as a kill switch, this was one of my anti-theft SVA parts.
coyoteboy
posted on 26/12/13 at 04:46 PM Reply With Quote
Also if you have it on the negative side and short ANY earth to the chassis you will keep the car live (and potentially set it alight). That's why the kill is on the +ve, so it works
https://www.fixmystreet.com/
posted on 26/12/13 at 05:29 PM Reply With Quote
I don't quite understand this; unless part of the chassis contacts the actual battery -ve post, then it will remain isolated. All earths are connected to the chassis anyway, so how can you "short" an earth to the chassis?
The low current switch on the FIA isolators is electrically isolated from the high current isolator, so even with the isolator in the battery ground cable you can still use one pole to switch a resistor from the positive battery to ground to load the alternator, and break the ignition circuit with the other pole.
posted on 27/12/13 at 06:21 AM Reply With Quote
MikRJ is correct on this
steve m
posted on 27/12/13 at 09:32 AM Reply With Quote
Thanks Guys
Its going to be on the neg side, as that is the neatest routing,
also, it is just to immobilize / added security and avoid any battery drain (that I used to have, but seem to of fixed now)
regards
coyoteboy
posted on 31/12/13 at 08:27 PM Reply With Quote
Depends on how you wire the isolation. I have seen a number of cars where the battery -ve and chassis are connected and all other electronics are "isolated" through their own ground through the isolation switch. This naturally doesn't isolate anything. If you link the only ground through the switch you have at least negated this issue, but it's not uncommon for people to do it the wrong way and the +ve isolation avoids the inherent problems when people subsequently start running their own unswitched grounds to items.
blakep82
posted on 1/1/14 at 12:36 AM Reply With Quote
putting it on the negative side, is there a risk that things like the throttle cable may still provide an engine earth? possibly overheating it and perhaps melting? a bit like sticking a bit of wire over the terminals of a 9v battery?
or that the gearbox mount might still provide a route to earth? from my vague memory, the gearbox mount on my car is a metal mount, with a bolt through it to the gearbox, with a rubber sandwich in between, but still metal to metal contact through the bolt. ie, it may not be a reliable way to disconnect the circuit?
________________________
ReMan
posted on 1/1/14 at 01:21 AM Reply With Quote
But if the vehicle earth (chassis, engine gearbox, throttle cable or anything else) is not connected to the battery -ve terminal, then it is not earth and nothing happens
So in that respect it is no more likely for something to touch an isolated battery negative terminal than an isolated a battery positive terminal
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
blakep82
posted on 1/1/14 at 01:26 AM Reply With Quote
ah of course, yeah, i'm thinking of it being in the engine earth, duh.
erm, but isn't the point of negative earth cars to help prevent corrosion by keeping it with a healthy supply of electrons? i seem to remember something in chemistry about that. you'd lose that benefit,
steve m
posted on 1/1/14 at 09:13 AM Reply With Quote
The corrosion problem was caused by all the positive earth cars, hence the change to negative
[Edited on 1/1/14 by steve m]
