Author: Subject: anyone made fiberglass springs?
v8kid
posted on 1/1/14 at 10:29 AM Reply With Quote
I seem to remember some commercial light van manufacturer making fiberglass is similar semi eliptic springs.
Any experience of this out there?
The application I have in mind is for a lightweight motorized buggy with a traverse semi eliptic spring at the front and quarter eliptic springs at the rear moulded into the main chassis rails.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
ste
posted on 1/1/14 at 11:08 AM Reply With Quote
Some detailed info here
http://www.birl.ethz.ch/research/publications/publication/projreport/AnastasiadesGRP2011.pdf
HowardB
that sounds very much like the A frame chassis on an austin 7. There was a lot of work done on grp springs, don't recall it ever going commercial. There is an issue with interlaminar shear strength for large deflections. However If the buggy is very lightly loaded then something should be possible, depends on how much travel you require.
A quick search shows work being done on the subject as recently as 2002.
For something truly light weight perhaps laminated wood might be an option,.. ?
hth
HNY
Howard
HowardB
posted on 1/1/14 at 11:35 AM Reply With Quote
That is very interesting, very much in line with the development work on sulcated springs done sometime in 70's / 80's
Howard
gdische
posted on 1/1/14 at 12:06 PM Reply With Quote
Corvettes have had transverse fibreglass springs for some time. When I worked at GM in the 1980s I was involved in designing composite elliptical springs for vans.
Google will find quite a lot of information about fibreglass elliptical springs.
Geoff
Volvorsport
posted on 1/1/14 at 12:15 PM Reply With Quote
Volvo v90 IRS.....they have a composite transverse rear spring on the mk2 models. Was quite common in truck industry untill airbags came along
www.dbsmotorsport.co.uk
getting dirty under a bus
scott h
posted on 1/1/14 at 12:21 PM Reply With Quote
Something rings a bell that Sherpa vans had fiberglass rear springs, don't quote me though!
CNHSS1
posted on 1/1/14 at 12:32 PM Reply With Quote
blimey! a bit of a Sherpa that didn't rust, well I never!
we ran some from new 'back in the day', had bodywork rust in under 4 months!!
v8kid
posted on 1/1/14 at 03:56 PM Reply With Quote
Excellent link I had not found before thanks
v8kid
posted on 1/1/14 at 04:18 PM Reply With Quote
hth
HNY
Ta for info - was the problems with interlaminar shear connected with polyester resins? If so epoxy resin should cure that. I'm not looking for ultimate low weight so all the fibres don't have to be unidirectional so the only problem would be in the y direction ie going from compressive to tensile strength and since that should always be compressive separation hopefully would not be a problem.
Have I caught the gist of what you were saying?
Cheers!
v8kid
posted on 1/1/14 at 11:11 PM Reply With Quote
Ah worked it out now!
