Author: Subject: welder probs
vysie
posted on 14/1/14 at 09:25 PM Reply With Quote
welder probs
my old man has gave me a welder now the problem is it a mightymig 105 turbo im guessing its no good for the build as its 105amps. the problem is the torch is missing the neck fires wire fine etc and has a gas bottle inside. so do i look for a new torch and practice with it on some off cuts or stick it on the auctions and add money towards something better
onwards
cliftyhanger
posted on 14/1/14 at 09:50 PM Reply With Quote
Depends what you want/need to weld. I have done plenty of car stuff with a 90a Clarke mig. That was rather good on panelwork. But also did a fair bit of chassis work.
105a should be ok with 3mm steel without any issues.
As to spares, plenty available on the bay. I think weldequipe is the well-liked seller.
MikeR
posted on 14/1/14 at 10:07 PM Reply With Quote
what he said. did most of my chassis on a 100 amp cebora. only got the 150 amp clarke when i fried the cebora. (running 3 data centre cooling fans against the open case to improve duty cycle - lasted a hell of a time too.)
posted on 14/1/14 at 10:41 PM Reply With Quote
If it's in good order, it should be fine for a Locost build. I recently borrowed a Sealey 110 A machine to build a go kart in 3mm wall box section and after a bit of practice it was possible to get good penetration and tidy welds. Since bought a Clarke 151 which doesn't really weld much thicker, just carries on for longer before it needs to cool down.
vysie
posted on 15/1/14 at 12:39 AM Reply With Quote
ill treat her to a new torch and tidy up then. ill get practicing on the go kart 1st see how it goes.
question about the gas use it or not?
onwards
owelly
posted on 15/1/14 at 09:56 AM Reply With Quote
You'll get a better weld with gas and gas (non-flux) wire is cheaper however, some say that if you're welding outside in breezy conditions, gasless wire is better. Personally, I just turn the gas feed up a bit.
http://www.ppcmag.co.uk
