Sadly, for sale shortly Indy R1
MK Indy R1 - 2011 £10,800.00 o.n.o huge specification,
Car first registered 20/12/11 FR61OOB
MK Indy works chassis with R1 engine which came from a crashed bike with under 4000 miles, purchased complete.
Has new sump baffle & new plumbed in catch tank
All correct High Tensile nuts & bolts where needed the rest being 99% stainless steel including rivets , self tappers, etc.
New MNR reversing gearbox with 2 new props rear one being TRT.
Refurbished LSD, / all new bearings throughout entire car. Front & rear.
New Wilwood 4 pot callipers with solid discs to front, drums to rear with all new cylinders shoes, / Stainless flexibles, / new handbrake cable.
4 pipe brake system with Sunny 1.8 gti master cylinder./ Rear bias valve.
Full Rollcage with high level led brake lights ,wired inside roll tube / aero screen,/ paddle gear change,/ Momo quick release steering wheel, /
longacre mirror
Team dynamics black CRX 13” wheels with Toyo R888 tyres almost as new.
Fitted new rose jointed top wishbone these are stronger & help to self centre.
All the rest of the wishbones are poly bushed all round.
New Quickrack, / Fully adjustable new Protech coilovers.
4 into 1 stainless steel manifold with silencer + 2 spare ones, very loud, loud & not so loud
Along with a new American cat and decibel killer should you need for MOT
Mk lightweight trimmed seats driver only adjustable, / 4 point Sabelt harnesses, / passenger footrest. Top filling 6 gall aly tank baffled with non
return valve breather & filter.
Exup motor, / all re-in forced main silicone hoses
New stronger clutch & iridium spark plugs 30 miles ago.
Koso RX1 multifunction clock , / Savage switches with push button start.
Racetech gauges , mechanical oil pressure & water temp , + petrol gauge.
Toad immobiliser ,/ cut off switch, / 12v power outlet ( for tomtom etc)
New Crystal headlamp units halogen .
Sierra front swivels have been drilled tapped & bolted.
Nosecone is on Stainless steel piano hinge.
New CSR front wheel arches (to modernise)
Sump protection skis, ( you will fly rather than tear the sump off ) , Fire extinguisher (dry powder), not plumbed in. Rear grilles to back panel
to reduce parachute effect,
Laser set up including tracking front & rear.
All electrics fully documented , wires run in flexible conduit. colour coded drawings
Have photos of every stage of the build & all component receipts.
Yamaha Manuals for bike & including Haynes manuals for bike & Sierra.
Performance is outstanding the early R1 engines being lighter than the later ones.
You will go a long way to find any kit car with the same specification. Car is taxed.
Rene 07831 422159. near Gatwick airport Sussex.
[Edited on 15/1/14 by renetom]
