daniel mason
posted on 29/1/14 at 11:43 PM |
strange power loss on tin top? s60 D5
i had a strange episode tonight with the volvo losing power. i was on my way to the gym,(5 mile trip) and just as i was about to come off the duel
carriageway at around 70mph i lost all drive and revs until the speed dropped to circa 40 mph,and rpm to around 2k, then it would not accelerate and
revs did not rise even when i went down through the gears! i limped to the gym carpark, turned off ignition,re started it and it was ok?
set off to drive home and within half a mile it did it all again,so pulled in,off with ignition,back on and it ran fine all the way to supermarket and
all the way back home!
any ideas what this could be? car is a 2002 volvo s60 D5 auto with only 76k,and full history,mot's etc!
one thing i do sometimes have is a scrambled warning message on dash saying coolant level low, but coolant is fine and i assumed a failed sensor(which
occured when i had the garage do the cam belt,and had to remove the header tank).its been like this for over a year though and never had a single
issue with the car.cheers
NigeEss
posted on 30/1/14 at 12:50 AM |
Had very similar today with a customers XC70 AWD diesel with the added issue that
occasionally it would cut out but on restart was fine till about 2k rpm.
Recorded low fuel pressure, turned out to be blocked fuel filter.
Strangely, the engine light never came on but it recorded the fault. Cleared it and once it lost power the
code was back in the memory but still no light.
[Edited on 30/1/14 by NigeEss]
Andy W
posted on 30/1/14 at 06:49 AM |
Try unplugging the MAF sensor, see if this improve it as a test.
I had similar problems last year. New MAF sorted it
sdh2903
posted on 30/1/14 at 08:22 AM |
First of all you need to get the Dash (dim) module sorted. The garbled message on the LCD is one of the first symptoms of it breaking down, the
failure of this module can cause no end of problems including the car not running at all, abs/airbag warnings, lights working erratically and loads
more. If you google dim module on the Volvo forums you will get loads of examples.
New modules are mega bucks and you can't fit a good used one from another car without getting it configured to your car, a company called BBA
reman down South will do a complete overhaul with a lifetime warranty for reasonable money.
I learnt all this on my dad's former s60 d5, we were getting some weird electrical faults along with the car dying a couple of times. All sorted
by getting the dash module overhauled.
adithorp
posted on 30/1/14 at 10:08 AM |
Sounds like it's going into limp home mode. You'd expect a fault/MIL light on as well but not always the case. Could be a lot of things
causing it and only a code read will find it. If there's no MIL on then it's likely that a straight forward EOBD read won't find it
and it'll need smething that reads the Volvo specific codes.
Dash faults are known issue but symptoms can also be CentralElectriclModule fault. Have a search on BBA-Reman
forum for more info.
Sorry but "My car did this and it was X so change that" is a bit of a lottery to just follow. There's dozens of possible casuses of
http://jpsc.org.uk/forum/
McLannahan
posted on 30/1/14 at 01:16 PM |
You can do some very basic displaying of DTC's with the onboard computer. It's not the most helpful as they may be old codes set but might
be worth a look? I had mine reset with VIDA soon after I bought my S60 so I know my codes displayed are fairly fresh.
http://forums.swedespeed.com/showthread.php?65822
Wheels244
posted on 30/1/14 at 07:00 PM |
Do you use Tesco Diesel ?
Fuel filter on my Evoque blocked with this stuff - common problem on them.
Same symptoms as yours apart from it lit up the engine management light.
Build Blog: http://wheels244.wordpress.com/
daniel mason
posted on 30/1/14 at 07:22 PM |
texaco currently.from local spar!
Wheels244
posted on 30/1/14 at 07:31 PM |
Mmmm - you would have thought Texaco was decent stuff.
Might be worth changing the fuel filter anyway if it's cheap and easy to get to - it would rule it out.
The Landrover Assist bloke showed me some 'fresh' Tesco diesel that he'd drained out of a tank - looked like something was living in
the bottom of it !
Volvorsport
posted on 30/1/14 at 07:59 PM |
*shudders at the thought of s60 electrics*
Not helpful I know
www.dbsmotorsport.co.uk
getting dirty under a bus
BigLee
posted on 30/1/14 at 08:09 PM |
Had the same symptoms on my V70. Weeks of chasing round with inconclusive fault codes. Turned out the fuel filter had collapsed so was restricting
flow. Sometimes it's the simple things. Hope you sort it Dan. S60's are great cars with the D5
daniel mason
posted on 30/1/14 at 08:37 PM |
car is superb, its just intermittent faults are a pain to find/trace!
GordR
posted on 30/1/14 at 10:43 PM |
As mentioned a couple of times already, I had a customers car come back into which was loosing power and going into limp mode. Fuel filer cured
that.
If you want to borrow my code reader let me know Dan.
daniel mason
posted on 30/1/14 at 11:06 PM |
might take you up on that mate, if i pop round next sunday to look at your radical,will you have it there? cheers gordon
fsmlittler
posted on 5/2/14 at 03:25 PM |
Just had very similar problem with a VW transporter. After spending a fortune changing parts it turned out to be a blocked catalytic converter.
mcerd1
posted on 5/2/14 at 04:05 PM |
but old diesels don't generally have catalytic converters or DPF's- and I'm pretty sure that 2002 volvo diesels don't...
even on the newer ones its far more likely that the Diesel Particulate Filter gets blocked because you haven't given it a good boot up the
motorway every now and then
daniel mason
posted on 5/2/14 at 05:52 PM |
it drives perfectly if you drive it normally. but if you go WOT when trying to overtake, it instantly does it which is a pain (and dangerous).
luke2152
posted on 16/2/14 at 02:48 PM |
This is classic maf sensor case in diesel audis. Would imagine volvos would be similarly affected. The unplug the maf to test doesn't always
work but if you have no luck with the fuel filter I'd be trying a new maf sensor
daniel mason
posted on 16/2/14 at 04:37 PM |
if i unplug the maf it just wont rev at all. exactly the same symptoms as when i go wide open throttle? its a puzzling me a bit!
basically if i drive it normally,there are no issues. if i open throttle fully it goes into this fault/limp mode. if i unplug the maf it goes into
limp mode straight away!
