Author: Subject: Front mudguards and IVA
gaz05
posted on 1/2/14 at 03:19 PM Reply With Quote
Just hoping someone can clear something up for me.
The manual says wheel arches must be turned in or have radius of 2.5mm. Yet it also says that class fibre panels must have 1.5mm radius. Which applies to front mudguards?
I hate trim so I'd rather build up my mudguards to be able to radius them 1.5mm.
40inches
posted on 1/2/14 at 03:54 PM Reply With Quote
The easiest way is to trim them, then remove after IVA
ali f27
posted on 1/2/14 at 05:20 PM Reply With Quote
I will second that trim them then remove worked for me simples
chrism
posted on 1/2/14 at 05:27 PM Reply With Quote
Yeah as above, just trim them for the IVA and then the trim can magically fall off after the IVA, will save you a lot of headaches and time doing something the hard way.
A little hard work never killed anyone, but why take the risk!
smart51
posted on 2/2/14 at 12:51 PM Reply With Quote
when I made mine, I made them 5.5mm thick at the edge and rounded it off before painting. Job done.
