Author: Subject: Garage Clearout
davidimurray
posted on 9/2/14 at 09:23 PM Reply With Quote
Garage Clearout
Having a clearout from the garage and have a few bits for sale. If your interested drop me a PM.
Pair of round IVA safe rear reflectors – never used as bought 2 sets by accident. £5 inc P&P to UK
Digital Sound level meter. Bought this to check my car for IVA so only used about 4 times. In virtually as new condition in box and with user manual. It is an SL-5868 but does not have the USB interface of some newer models. £35 inc P&P to UK
Handbrake/Gear stick surround. I made this for my own car but cocked up and made it the wrong size! CNC machined from 2mm thick aluminium. Outer dimensions approx 175x105 with the rim being 17mm wide. Holes are drilled 6mm clearance. This is as it came off the machine so needs deburring and cleaning up. £7 inc P&P to UK
Carb balancer – 2 cylinder type but can be used on cars etc. Just the two gauges on a backplate, no hoses included. £12 inc P&P to UK SOLD
Wipac 95mm rear red lens, unused. Does not include bulb holder. NOT suitable for IVA foglight. £6 inc P&P to UK
Exhaust end cover. I made this to cover the bolts/flange on the end of my bike can I fitted. Made from a dog bowl, it has a hole(50mm dia) to go over the exhaust link pipe, inside are two brackets over which a jubilee clip (not included) to hold it in place. Edge is all fitted with edge trim and hole for fitting jubilee clip is capped. 165mm diameter overall. IVA inspector loved it. £7 inc P&P
Set of seat runners – had 2 seats, 1 of which is now fitted to my car. These are from the rear seats of some French people carrier, so in used condition. Only 27mm high. £12 inc P&P to UK
10 M12 nut/bolt head covers – 3 sets available. £2.00 per set inc P&P to UK
10 M10 nut/bolt head covers. £2.00 inc P&P to UK
10 M8 nut/bolt head covers. £2.00 inc P&P to UK
[Edited on 10/2/14 by davidimurray]
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
r1_pete
posted on 10/2/14 at 08:03 AM Reply With Quote
I'll have the Vac gauges if still available.
PM on its way.
lmillin123
posted on 11/2/14 at 08:05 PM Reply With Quote
Are the reflectors still available?
davidimurray
posted on 12/2/14 at 09:05 AM Reply With Quote
Sorry Reflectors sold
davidimurray
posted on 16/2/14 at 06:27 PM Reply With Quote
Bump
Reflectors, gear surround and vac gauges sold.
Rest still available.
davidimurray
posted on 31/3/14 at 09:26 AM Reply With Quote
Bump
Sound level meter reduced to £30 inc UK P&P
Exhaust End cover £5 inc UK P&P
Seat Runners and nut covers still available
Gaz4562
posted on 31/3/14 at 03:32 PM Reply With Quote
Ill take a set of each of the nut : bolt covers.
davidimurray
posted on 31/3/14 at 05:02 PM Reply With Quote
Gaz - u2u sent
[Edited on 31/3/14 by davidimurray]
rash12
posted on 31/3/14 at 05:58 PM Reply With Quote
what size af are the 12mm nut covers please if they are a 19mm hex I will have a set pls u2u sent
[Edited on 31/3/14 by rash12]
