Author: Subject: Fuel Tanks
Neb
posted on 28/2/14 at 12:46 PM Reply With Quote
Fuel Tanks
In the market for a fuel tank for the Locost at the moment and had a look at a few on-line, all somewhere around the same price.
Any recommendations for manufacturers/suppliers? It'll be for a Carbed car.
I've had an ally one split before in Tanzania in the Escort made by a very reputable company and don't want to make the same mistake again.
posted on 28/2/14 at 01:47 PM Reply With Quote
I am using a plastic one out of a boat...
http://www.marinescene.co.uk/product/814/-inboard-fuel-tank-medium-profile-33ltr-
loggyboy
posted on 28/2/14 at 01:58 PM Reply With Quote
Will the approval of those carry over to cars for IVA?
Or are you adding post IVA?
Mistral Motorsport
Nickp
posted on 28/2/14 at 02:07 PM Reply With Quote
Interesting. Do they have any sort of baffles or would a swirl pot be required?
posted on 28/2/14 at 02:38 PM Reply With Quote
Theres no baffles in the tank and I used an injection pump sender unit from a Mk6 Fiesta.. spent ages adapting it into the deck plate. Then decided to go with carbs so will be replacing the high pressure pump with one of a V8 Landrover.
One of these from a carbed V8, it pumps at 1.5psi and is interpreter the same as a bike pump effectively.. Just swap the pump bit into the housing and should be OK.
Part number is PRC7020 and pay no more than £20...
Neb
posted on 28/2/14 at 05:06 PM Reply With Quote
I had a look at the plastic ones and came to the conclusion that it wasn't IVA'able after reading some threads on here. I've struggled to find one that fits the 'ole too.
My car requires an IVA (hopefully this year!)
Shouldn't really need a swirl pot for a carbed car. I'm using DOCE's so would require 4psi ish was going to use a facet.
Any ideas on Ally ones? Unless someone has IVA'd with a plastic one?
Nickp
posted on 28/2/14 at 05:14 PM Reply With Quote
Unless you want to 'attack' corners such as Gerrards
Neb
posted on 28/2/14 at 05:29 PM Reply With Quote
Again we don't run one on the Escort (stage rally car) and never have any issues even on slicks. One of the filter king units under the bonnet holds enough not to starve the float chambers.
The tank i would use would be baffled so should be ok in the 7. Again we would run a filter king close to the carbs.
So any ideas on Ally tank manufacturers? Good experiences with OBP?
