Author: Subject: Quieter option for the Facet pump
pekwah1
posted on 28/2/14 at 03:29 PM Reply With Quote
Hi Guys,
I am amazed by the 'volume' of my facet low pressure pump.
Is there a suitable alternative which won't sound like someone has a pneumatic drill running in the back of my car?
Regards,
jeffw
posted on 28/2/14 at 03:41 PM Reply With Quote
http://atspeedracing.co.uk/products/index.php?main_page=product_info&products_id=51
Ben_Copeland
Is it bolted straight to the chassis or on rubber mounts? Rubber can reduce the noise some what
Ben
Locost Map on Google Maps
Enter Your Details Here
turnipfarmer
posted on 28/2/14 at 04:20 PM Reply With Quote
+1 for rubber mounts
You'll be amazed at the difference something like this makes...
FACET FUEL PUMP ANTI VIBRATION RUBBER MOUNT FITTING KIT SYTEC QUALITY
pekwah1
posted on 28/2/14 at 04:27 PM Reply With Quote
well it is going to the chassis, i did try rubber/foam to try to reduce the noise, but nothing as substantial as that.
r1_pete
posted on 28/2/14 at 05:53 PM Reply With Quote
I'm running one of Mgb Electronic Fuel Pump Azx1307z New Boxed Item With Fittings on my E Type, 250bhp 4.2L, ran one on the mgb before. Its quiet, and an interrupter, so cuts out when up to pressure.
SPYDER
posted on 28/2/14 at 06:52 PM Reply With Quote
Try mounting using WELL NUTS.
pekwah1
posted on 28/2/14 at 08:33 PM Reply With Quote
Yeh i've used those before at work, didn't find them to be a particularly reliable fastener....
beaver34
posted on 28/2/14 at 08:39 PM Reply With Quote
mounted mine on exhaust bobbins, quiet as a mouse
pekwah1
posted on 28/2/14 at 08:59 PM Reply With Quote
cheers guys, i'll give the bobbins a go!
posted on 28/2/14 at 09:32 PM Reply With Quote
You ideally want the rubber bobbins sold for fitting LPG injector rails, they are very soft with M6 threads designed to dampen a very similar problem.
