Author: Subject: Bleeding brakes, air!!
steve m
posted on 9/3/14 at 12:47 PM Reply With Quote
Hi all
I have bled brakes countless times and never had this problem
Ive fitted a an OBP floor mounted pedal box setup, and can not get all the air out of the brakes with
two master cylinders
im using new fluid, there are no leaks, and had the pedal wedged over night so whole system
pressurised
The brake peddal is pretty solid, and does not appear to go down and has minimul movement
yet i still can get air bubbles out every time i bleed the brakes
any one else had this problem?
steve
posted on 9/3/14 at 01:18 PM Reply With Quote
It is not unheard to have a one way leak ie. a joint is fluid tight under pressure be draws air on the return stroke.
Oddified
posted on 9/3/14 at 02:35 PM Reply With Quote
It's quite possible that it looks like the air bubbles are from the system but in fact it's air getting in past the bleed nipple threads and isn't actualy from the brake system itself. More so if you have long bleed pipe running down to the floor into a bottle.
Ian
40inches
posted on 9/3/14 at 02:49 PM Reply With Quote
Try wrapping the bleed nipple threads with PTFE tape (not the sealing taper though).
AntonUK
posted on 9/3/14 at 02:54 PM Reply With Quote
I had this on the wife's civic.
I put a load of grease around the threads of the bleed nipple while bleeding, its stoped air being pulled via the threads.
Once bleeding was done i just cleaned it off and jobs a goodun.
Build Photos Here
steve m
posted on 9/3/14 at 03:02 PM Reply With Quote
Good idea's and much better than Bt's suggstion !!
Bt, point noted, but hope its not as you suggest
posted on 9/3/14 at 03:11 PM Reply With Quote
Even a tiny ammount of hydrocarbon oil in a brake system will cause problems that won't show until a couple of years down the line.1
lmillin123
posted on 9/3/14 at 04:56 PM Reply With Quote
Had the same fault with obp set up. Had 2 brand new master cylinders and kept getting air out the back pipes. Stripped master cyl and found seal had turned the wrong way. Cleaned and lightly greased on rebuild and hey presto.
steve m
posted on 9/3/14 at 05:21 PM Reply With Quote
Thanks, i did wonder the same
steve
supersport31
posted on 18/3/14 at 11:12 PM Reply With Quote
Have you tried cracking open any of the brake line joints while bleeding. A surprising amount of air can be lurking where the pipes join the master cylinder.
steve m
posted on 19/3/14 at 07:15 AM Reply With Quote
I have not tried that,
There is not much of a difference between the old setup, and the new, plus the front system is "EXACTLEY THE SAME"
and there does not appear to be any air in the front
but I did contact OBP. and asked them if they knew of anything I could of done was wrong
And they wanted the MC back asap, and would replace it FOC
hopefully will be waiting for me on in the post tonight
steve
JAG
posted on 19/3/14 at 10:31 AM Reply With Quote
In two places on this thread people have admitted to mixing Mineral oil based products with brake fluid.
Stripped master cyl ..... Cleaned and lightly greased
I hope you're keeping a close eye on your brake systems because this Mineral oil will eventually damage the seals and leave you with jammed on brakes or no brakes at all.
Good luck everyone
Justin
