Author: Subject: Possible to modify Polo radiator? Tips for other rad?
Kghaas
posted on 12/3/14 at 07:16 PM Reply With Quote
During mapping of my engine, my old radiator sprung a leak. I have a VW Polo radiator witch I bought without having the right measures.
When I now want to install it, it is way to wide.
This is the cheapo version with plastic ends/tanks.
Question: Is it possible to take off the plastic end, cut the radiator core and get it back together without leaks? Any links or tips on this?
My alternative is to get an custom alu radiator, which I at the moment don't want to do...
pmc_3
posted on 12/3/14 at 07:27 PM Reply With Quote
There are several different versions of the polo radiator with different core sizes, the usual one is something like 380mm iirc
gremlin1234
posted on 12/3/14 at 07:51 PM Reply With Quote
short answer, NO,
long answer, unfortunately, no.
mending your old rad would be far simpler
johnemms
posted on 12/3/14 at 08:02 PM Reply With Quote
You can take the sides off..
I changed the sides on my polo radiator ..
I used a golf gti sides with rad fan with 2 speed switch...
I bought a polo radiator took off the sides & also bought a spare core no sides..
(still on the shelf in case of mine getting busted)
VW Gti Rad Fans & new core
polo rad vw gti  fittings
[Edited on 12/3/14 by johnemms]
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
posted on 12/3/14 at 09:12 PM Reply With Quote
Old style Mini Cooper side mounted rad is the smallest rad you will find with decent heat transfer area.
swanntech
posted on 16/3/14 at 08:54 PM Reply With Quote
Radiators
early merc 190 e radiator are cheep and easy to fit
