Author: Subject: wiring a start button
john_p_b
posted on 26/3/14 at 04:15 PM Reply With Quote
childish perhaps but in with the various mods i've done over winter i've decided i need a start button on my indy and do away with the key/barrel/lock set up altogether.
it's a pinto powered car with a vicky green loom. to the original ignition there is:
Brown - battery +?
white - switched live?
white/red - goes to the solenoid but also sounds out if i put my meter to ground?
so i have a simple toggle switch for ignition (with illumination) with a push button start to make it go vroom.
i'm sure i'm just being blonde somewhere as it's only 3 wires to pick from but can someone explain what got to what?
many thanks.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
cs3tcr
posted on 26/3/14 at 04:23 PM Reply With Quote
Brown is the feed to the ignition/start switch, so to wire a separate push button you will need to do the following:
- brown to one side of the toggle (ignition) switch, white to the other
- another white wire from the toggle (ignition) switch to the push button
- white/red from push button to starter solenoid
[Edited on 26/3/14 by cs3tcr]
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 26/3/14 at 05:09 PM Reply With Quote
If you haven't got a button yet - I have a savage start button surplus to requirements. It came from my pinto powered Indy
john_p_b
posted on 26/3/14 at 09:30 PM Reply With Quote
Thanks for the reply, another job I can tick off the list.
Thanks for the offer of the savage switch but I've already bought mine.
