perksy
posted on 26/3/14 at 10:49 PM |
Cleaning Patio Slabs
Need to clean mothers patio slabs, They have the usual build up of grime.
Have the trusty power washer but has anybody found a solution that works to clean the grime off before blasting the residue with the power washer ?
Thanks.
Scuzzle
posted on 26/3/14 at 10:56 PM |
I scrub mine with detergent and a wire bristle broom before blasting it with the power washer.
JohnH
posted on 26/3/14 at 11:06 PM |
The cheapest and one of the best ways to clean any patio, is to buy some cheap bleach and mix it pretty strong, then pour it over the patio and leave
for at bit. Then use a stiff yard broom to give it a good scrub,then hose off. It should come up nice and clean.
Staple balls
posted on 26/3/14 at 11:17 PM |
Biological washing powder, water and a stiff brush.
Mr C
posted on 26/3/14 at 11:53 PM |
Any of the above but use a proper patio cleaning attachment rather than a high powered nozzle, you'll be there all day with a jet, and
it'll be strippy.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
snapper
posted on 27/3/14 at 06:43 AM |
The other problem with jet washing is the you can take the surface finish off the slabs then cleaning them next time needs more work and you take more
surface off
I eat to survive
I drink to forget
posted on 27/3/14 at 07:04 AM |
Thanks.
+1. Cheap thin bleach. 50% water spread with soft brush.
v8kid
posted on 27/3/14 at 07:56 AM |
Bleach gives quick results but does not have much resilliance. Jeyes fluid lasts longer but takes longer to effect. Also bleach bugger's wood
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
AdrianH
posted on 27/3/14 at 08:08 AM |
just a bit of personnel advice on a bit of safety.
Use a filter mask when power washing the flags, may sound or look daft but you end up with a lot of water vapour that you are breathing in, this will
probably contain the cleaning agent you use plus particles of moss, mould and any other fungal or bacterial crap from the flag surface.
Use if you can use one of the patio cleaner accessories (rotating nozzle's) rather then just a blast it lance, less spray back.
Recovering from chest infection that went to pneumonia, that I suspect was down to cleaning my flags over a two day period back in January.
Adrian
[Edited on 27-3-14 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Irony
posted on 27/3/14 at 08:24 AM |
One of the guys on here did the same thing and power washed his patio. Turned out he had some blue green algae in the crevices and he power washed it
and breathed it in. Told me it more or less retired him.
Get a mask!
Irony
posted on 27/3/14 at 08:26 AM |
Also a great long lasting weed killer is a full bag of salt in a watering can full of water, dissolved, then brushed into the cracks. Locost!
[Edited on 27/3/14 by Irony]
theprisioner
posted on 27/3/14 at 08:34 AM |
There is a product called Algon, it is not cheap but does exactly what is says on the container. It can last up to several years and brings the colour
back to whatever cement product it is applied to. No scrubbing, poisoning the planet or effort for that matter!
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
perksy
posted on 27/3/14 at 06:15 PM |
Thanks for that lads, Very helpful
I must confess i hadn't thought about wearing a mask, But i will make sure i do now
nero1701
posted on 27/3/14 at 06:47 PM |
cheap cola and a brush
posted on 27/3/14 at 07:34 PM |
Get a mask!
If it who I think it is (former Viento owner?) then yes . Use a mask! You know it makes sense
Simon
posted on 27/3/14 at 08:45 PM |
New slabs
Simon
