Author: Subject: Slight misfire / Hesitant
Jasmcauley
posted on 4/4/14 at 12:26 PM Reply With Quote
I have an MK Indy Blade
it has a CBR 900RR Fireblade 918/919CC engine
it pulls really well in first and second, but as soon as I get to about 60-70MPH
it seems to be a little hesitant, almost like a missfire at about 70MPH and doesn't want to pull any more.
I have bought new spark plugs to fit this weekend, and I was going to try and change the fuel filter but the one I have isn't like for like so it isn't long enough without changing the pipe work.
Any other suggestions?
www.plant-i.co.uk
GPS tracking security
davidimurray
posted on 4/4/14 at 12:45 PM Reply With Quote
Try balancing the carbs/TBs.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
mark chandler
posted on 4/4/14 at 06:54 PM Reply With Quote
When I changed the exhaust on mine it had similar issues, have you changed anything, exhaust/inlet as these engines are very sensitive, went from standard R1 can to straight through, to address i fitted a dynojet kit.
New plugs are also a good start.
matt_gsxr
posted on 4/4/14 at 07:43 PM Reply With Quote
Check the plugs before replacing them. Might indicate that one carb has restricted flow.
Jasmcauley
posted on 5/4/14 at 08:07 PM Reply With Quote
Many thanks guys.
Runs like a dream up to 75ish so I'd imagine it's only something Small
I will check the plugs tomorrow and see if I can see any evidence of a restrictive carb.
www.plant-i.co.uk
