Author: Subject: Thermoforming acrylic sheet.
Hugh Jarce
posted on 7/11/04 at 02:56 AM Reply With Quote
Graber et al, this may be of interest:
LINK
The pay isn't very good , but the work's hard.
sgraber
posted on 7/11/04 at 05:20 AM Reply With Quote
niiiiiiiiice!
good info - thank you sir...
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
mangogrooveworkshop
posted on 7/11/04 at 11:50 AM Reply With Quote
Top marks for that link That is very useful! Seen it done by a guy once and its works well. Made fan belt covers for my baja bug that were see thru.
dern
posted on 7/11/04 at 03:24 PM Reply With Quote
Excuse my ignorance but is this the sort of thing one can do at home with a domestic oven, somekind of wooden former and a vacuum cleaner?
We made simple stuff at school (a long long time ago now) with thermoplastics and an oven , hence the question.
Mark
sgraber
posted on 7/11/04 at 04:01 PM Reply With Quote
Mark
Simply put - yes, yes indeed.
But I would probably not use the wife's oven or any oven indoors for that matter. The acrylic that I have heated up lets off some pretty nasty smelly's... Don't know if it's poisonous, but why take the chance.
Around here one can buy an old working oven at a garage sale for next to nothing.
Steve Graber
Hugh Jarce
posted on 7/11/04 at 08:14 PM Reply With Quote
For a heat source, you could also use a chipboard cabinet and a bank of those infra-red heat lamps as used in bathrooms, chip shops and poultry houses. They would give better flexibility to jobs that are larger than domestic ovens.
CooperLight
posted on 8/11/04 at 06:07 PM Reply With Quote
A looong time ago I did this in my parents oven.
Forgot to remove the plastic due to watching TV, melted plastic does not smell good in an oven, and it's virtually impossible to remove.
Lesson learned: get a dedicated oven !
tadltd
posted on 27/11/04 at 01:04 PM Reply With Quote
Another link if you fancy forming Lexan...
Click here!
VERY useful, descibes forming techniques, painting, fabrication, cutting, drilling, cleaning, etc, etc.!
Best Regards,
Steve.
www.turnerautosport.com
sgraber
posted on 27/11/04 at 03:58 PM Reply With Quote
Click here!
That's good, very good. I suspect that the mar-guard version of lexan would be very scratch resistant? Any other polycarb/lexan products that would be good for headlamp covers? From a scratch resistance perspective?
Graber
Steve Graber
tadltd
posted on 27/11/04 at 05:24 PM Reply With Quote
Margard is the stuff they use for helmet visors and, I suspect, headlamp covers on OEM cars (and will be used on the LMP).
Only problem is - in case you haven't read thro' all the info yet - draping it's easy but getting the optical clarity isn't. You need a mirror surface tool for the optical clarity, i.e. expensive if you're not going to produce more than one set!
However, the prototype covers on the LMP seemed acceptable enough from toolboard moulds (rough surface).
Best Regards,
Steve.
Rorty
posted on 3/2/05 at 08:52 PM Reply With Quote
Graber et al, this book on vaccum forming may be of interest.
Cheers, Rorty.
sgraber
posted on 4/2/05 at 12:24 AM Reply With Quote
Wow. i think I may have to get that.
Thanks RORT-man.
Graber
Steve Graber
sgraber
posted on 4/2/05 at 12:38 AM Reply With Quote
I bid on that book ^, so no-one else please!
And what about this book for steel tubular structure theory and design?
Way over my head...
Steve Graber
nick baker
posted on 4/2/05 at 12:43 PM Reply With Quote
I've used a purpose built vacuum former to create poly-prop moulds.... from which you can make fibreglass/carbonFire parts.
Very useful....
For really SMALL things, you can make a wooden plug and jam it into a plastic (PET) coke-bottle (or similar). wedge it in so it's very tight, and then attack it with a heat-gun or Oven.
The plastic bottle shrinks to fit the plug.. and again, you can use it as a glass-fibre mould.
maybe useful for someone
The Shootist
posted on 4/2/05 at 03:53 PM Reply With Quote
Bubbles with pressure
Bubbles shapes like the canopies for homebuilt aircraft are made by plumbing a piece of plywood for air pressure, then cut another piece into an out line of the hole the part will cover. Screw the 2 pieces together with lexan in between, and heat the entire assembly. Once up to temp, inflate the plastic dome to the desired profile and allow to cool.
Presto! a custom moulded canopy.
