Author: Subject: Home cnc
carlknight1982
posted on 13/4/14 at 06:53 PM Reply With Quote
Home cnc
How hard is it to construct a small say a3 size home cnc and use it to make small parts and engrave stuff
Bear in mind I'm a complete novice I just think it would be a cool toy
[Edited on 13/4/14 by carlknight1982]
Logic will get you from a A to B
Imagination will take you everywhere.
Theshed
posted on 13/4/14 at 07:13 PM Reply With Quote
Easy! But not all that cheap. All bits available from http://www.worldofcnc.com/collections/cnc-router-packages. Have a look at the Artsoft forum.
theprisioner
posted on 13/4/14 at 07:34 PM Reply With Quote
Took two years out of my life don't do it:
http://www.alastair-reynolds.pwp.blueyonder.co.uk/milling/
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
carlknight1982
posted on 13/4/14 at 07:50 PM Reply With Quote
I'm not looking to convert a manual mill
I'm thinking more like these
linky
zekill
posted on 13/4/14 at 07:55 PM Reply With Quote
mild steel is cheaper and stronger that ali, mine:
Fisher Fury with Phoenix bodywork, Blade 919cc
Trollyjack
posted on 13/4/14 at 08:55 PM Reply With Quote
I started to build one 5 years ago then got into building my car
Sold my frame but still got all the motors and built my own controller and pc alonh with it would sell if any one is interested
TrollyJack
coyoteboy
posted on 13/4/14 at 09:36 PM Reply With Quote
Rigidity is what you want, not strength.
I'm about 1200 quid into a manual mill conversion because I saw some routers in action, spoke to some machinists and concluded what most do after a router build - they're only really good for wood and 2.5D.
trextr7monkey
posted on 13/4/14 at 09:49 PM Reply With Quote
If you just want to do engraving keep an eye out for old camm 2 machines
or even the early Denford micromill stuff
Atb
Mike
davidimurray
posted on 14/4/14 at 09:24 AM Reply With Quote
As others have said, the problem with CNC milling is you need a good strong rigid machine. I have converted an X2 type machine to CNC and ended up making braces, filling columns with concrete etc. The small machines look nice in theory, but when you end up doing things like taking 0.1mm depth cuts the time taken to machine parts becomes very tedious - often simple parts can end up taking hours. To give an idea of scale I have a Denford Triac which I rebuilt. My old mill could be picked up by one person, the Denford is over 1/4 ton!
Have you considered 3d printing? Low forces so everything can be much lighter.
[Edited on 14/4/14 by davidimurray]
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
carlknight1982
posted on 14/4/14 at 10:44 AM Reply With Quote
Hadn't considered that as an option
davidimurray
posted on 14/4/14 at 11:30 AM Reply With Quote
I've been pondering building a 3d printer myself. Seems to be lots of versions out there.
There is some good info here - http://reprap.org/wiki/Build_A_RepRap
I was considering builidng a prusa of which there is a newer version out - http://reprap.org/wiki/Prusa
tegwin
posted on 14/4/14 at 02:30 PM Reply With Quote
3D printer is a good novelty but what would you actually use it for?
Be amazing if you could print in wax and had access to a foundry to turn the printed item into something useful....
www.verticalhorizonsmedia.tv
davidimurray
posted on 14/4/14 at 03:02 PM Reply With Quote
I did wonder this myself - and then started thinking about using it for rapid prototyping before I cut parts on the CNC mill. Things like alternator mounts, pedals, instrument housings, etc. I do know of people making RP plenums but they are using SLS, doubt a homebrew 3d printer could get anywhere near that.
Of course you could always setup a foundry at home and cast some aluminium bits
