<<  1    2    3  >>
Author: Subject: Sylva Phoenix - Supercharged - 397 BHP
jeffw
posted on 16/4/14 at 10:17 PM Reply With Quote
Just back from TTS Performance in Northampton who spent all day making and fitting a custom intercooler and pipework. Final Dyno run was 397BHP and 297 ft lb
[Edited on 16/4/14 by jeffw]
adithorp
posted on 16/4/14 at 10:28 PM Reply With Quote
No words, just...
Doesn't that put you around 640bhp/t ?
http://jpsc.org.uk/forum/
jeffw
posted on 16/4/14 at 10:30 PM Reply With Quote
620 Kg (without driver) gives 640BHP per ton.....or adequate as we say in Kent
Andybarbet
posted on 16/4/14 at 10:33 PM Reply With Quote
Fantastic - looking forward to seeing it at Debden, I will need a quicker camera now !
unijacko67
posted on 16/4/14 at 11:09 PM Reply With Quote
http://www.kittenkitcar.co.uk
ashg
posted on 16/4/14 at 11:11 PM Reply With Quote
That's a nice result Jeff ! Even more than you expected if I'm not mistaken. More importantly how are your charge temps looking after the new intercoler? Did you manage to get the claimed 15deg above ambient?
You must be one of the most powerfull zetecs out there now!
[Edited on 16/4/2014 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
yellowcab
posted on 16/4/14 at 11:29 PM Reply With Quote
shit the bed!
HowardB
posted on 17/4/14 at 01:02 AM Reply With Quote
Wow. . I have 170 and think for the most part that is adequate. ...
Howard
jeffw
posted on 17/4/14 at 04:56 AM Reply With Quote
inlet temps where down from 65+ deg C to a max of 34 deg C on the Dyno so yes, inlet temps down.
One of the biggest gains was when the air filter was changed from a CBS carbon can to a K&N cone filter, the car immediately gained significantly from 4000 rpm onwards. Of course without the rest of the changes it wouldn't have done this but even so I was shocked at the difference.
Anyone want to by a slightly used Carbon canned airfilter ?
[Edited on 17/4/14 by jeffw]
jeffw
posted on 17/4/14 at 05:07 AM Reply With Quote
TTS where great, they normally wouldn't do this work in 1 day but agreed to this time....Arrived at 0800hrs and left at 2030hrs and Darren still had to put his 600BHP Exige S1 back together for Friday at Angelsey. Great bunch of guys who worked very hard during the day I was there.
daveb666
posted on 17/4/14 at 07:16 AM Reply With Quote
Proper monstrous performance - what was the power/torque before?
What's the full engine spec?
BaileyPerformance
Bloody hell, your catching us up, we'll have to get out 462bhp zetec back in the workshop! :-)
That's really really good power for a supercharger setup, what boost are you running now?
HowardB
You need to change your signature,..
Howard
jeffw
posted on 17/4/14 at 07:34 AM Reply With Quote
1.2 Bar Dale. The crap airfilter (which I had forgotten about) was holding it back....a lot. So it gained 60BHP and 40 ft lb with the intercooler change/airfilter change and the inlet is now 34 deg C on an ambient of 20 deg C. Not too shoddy
matt_gsxr
Nice one Jeff. That intercooler certainly looks serious.
Also interesting that (what looks to me like) your polo radiator is up to the job.
Just one question. Where do you get your inlet air from? Is it drivers side "pod" behind the front wheel?
jeffw
posted on 17/4/14 at 07:36 AM Reply With Quote
Hi Matt
Yes, inlet is from the Pod on the drivers side. I'm going to put a lid on the sidepod and then put large holes in from the side for the airfilter to breath cold air.
Fieldy
posted on 17/4/14 at 08:05 AM Reply With Quote
Awesome, i bet thats a right handful!!!!
BaileyPerformance
posted on 17/4/14 at 08:07 AM Reply With Quote
Hi jeff, that's absolutely fantastic power at that boost, your whole setup must be very efficient.
We are running 27psi to see 462bhp
My 3 door Cosworth YB runs 30psi to see 360bhp
We are planning on getting the zetec turbo back in the workshop soon for MSD ignition upgrade, we also need to dial the cams in as there on ford marks at the mo.
I think we will see over 500bhp when we get everything sorted, the customer us running a stock RS turbo gearbox so I'm expecting that to blow soon!
ashg
posted on 17/4/14 at 08:15 AM Reply With Quote
The if I'm remembering things correctly the head on jeff's engine is a little bit special along with the cams rods and pistons.
jeffw
posted on 17/4/14 at 08:16 AM Reply With Quote
Blacktop Zetec 2lt
CNC Heads Head and Cams
Omex supplied Rods and Pistons (11:1 compression)
Jenvey ITBs
700cc Injectors
Nissan Pulsar Flak Monkey inlet plenum
Bosch 044 Motorsport HP pump
AP clutch, light weight flywheel
Omex/TTS Rotrex Supercharger kit
TTS Intercooler
BGH E8 Type 9
English Axle, 3.54 to 1, Quaife ATB
The engine has gained 60BHP & 40 ft lb with the intercooler change
BaileyPerformance
posted on 17/4/14 at 08:30 AM Reply With Quote
Hi jeff,
May have asked you this before, would love to know your cam specs, we are using piper 285s.
jeffw
posted on 17/4/14 at 08:33 AM Reply With Quote
We could change the Rotrex out for a bigger one (C34) and would like see over 500BHP using 1.2bar. TTS had a 2lt Duratec in (in a Chevron) which made 480BHP on 1.2 bar with the bigger charger.
jeffw
posted on 17/4/14 at 08:35 AM Reply With Quote
Hi jeff,
They are more than the 285s Dale, I think it was 300 duration. Lift is not very big as they would run on stock pistons without a cutout. They are not really optimised for this application but seem to be OK.
jeffw
posted on 17/4/14 at 10:15 AM Reply With Quote
Koenigsegg Agera 4.7L V8 - [2010] 696.1 bhp per tonne
Koenigsegg CCX 4.7 V8 Supercharged - [2006] 683.0 bhp per tonne
Porsche 9FF GT9 - [2008] 680.6 bhp per tonne
Gumpert Apollo Enraged 4.2 V8 Turbo - [2012] 654.4 bhp per tonne
Bugatti Veyron 8.0 litre W16 Super Sport - [2010] 644.1 bhp per tonne
Jeff's Sylva Phoenix !!!!!! 640
Ferrari LaFerrari 6.3L V12 - [2013] 628.6 bhp per tonne
Gumpert Apollo S 4.2 V8 Twin Turbo - [2009] 616.6 bhp per tonne
Between 600 and 500 bhp per tonne.
Bugatti Veyron 16.4 Grand Sport Vitesse - [2012] 594.9 bhp per tonne
Caterham 7 620 R 2.0 L Supercharged - [2013] 570.6 bhp per tonne
Pagani Zonda Cinque 7.3L - [2008] 560.3 bhp per tonne
McLaren F1 6.0 V12 - [1994] 550.0 bhp per tonne
Ariel Atom 300 Supercharged - [1999] 545.4 bhp per tonne
Radical SR3 1.5 16V - [2001] 541.9 bhp per tonne
Bugatti Veyron 8.0 litre W16 - [2005] 530.1 bhp per tonne
McLaren P1 3.8 V8 Hybrid - [2013] 521.1 bhp per tonne
Noble M600 4.4L V8 - [2009] 520.0 bhp per tonne
Caterham 7 Superlight R500 - [2009] 519.7 bhp per tonne
Pagani Huayra 6.0L Twin turbo - [2013] 518.5 bhp per tonne
BAC Mono 280bhp - [2011] 518.5 bhp per tonne
Caterham 7 Superlight R500 - [2000] 511.1 bhp per tonne
Nissan R390 3.5L V8 - [1997] 500.9 bhp per tonne
striker-4age
posted on 19/4/14 at 01:46 PM Reply With Quote
U still running the Bgh box ? With that power how the hell do u keep up ?
<<  1    2    3  >>
