<<  1    2    3  >>
Author: Subject: S1 Lotus Elise stripping breaking
Pat_T
posted on 6/6/14 at 07:34 AM Reply With Quote
Originally posted by b14wrc
Does that fit the standard system? How does it work? What are the advantages of using it, apart from reduced warm up times?
http://wiki.seloc.org/a/Pressure_Relief_Remote_Thermostat
The other key advantage is basically to reduce the thermal shock the engine sees when the thermostat opens. This reduces the risk of head gasket failure hence why Land Rover themselves adopted this part/system on the K-series-engned Freelanders...
You could fit it to any engine though, I was considering using it with a V8 I have but in the end have decided not to run a thermostat as it's a track-only car...
cheers
www.instagram.com/patroclueus
Pat_T
posted on 8/6/14 at 12:59 PM Reply With Quote
thermostat now on ebay at 99p/no reserve - get yourself a bargain:
eBay Item
cheers
Pat_T
posted on 8/6/14 at 01:08 PM Reply With Quote
engine now gone.
standard K-series Rover ECU - £15 posted
Pat_T
posted on 13/6/14 at 06:11 PM Reply With Quote
wheels and tyres
listed here on MLOC:
http://www.midlandslotus.co.uk/forum/classifieds/item/507-wheels-tyres-recently-refurbished/
but would consider decent offers?
Pat_T
posted on 15/6/14 at 04:50 PM Reply With Quote
thermostat sold.
heater matrix - could be ideal for a kit car? EBAY 99p start no reserve!
S1 Lotus Elise Exige heater matrix &' hoses (Genuine OE Parts).
nearside mudflap
S1 Lotus Elise Exige front nearside mudflap (Genuine OE Part).
wheels & tyres available - need these gone ASAP as taking up room now they're off the car. Would take £250 from a locostbuilder!!!
Pat_T
posted on 19/6/14 at 06:51 PM Reply With Quote
wheels and tyres now on ebay - no reserve and need to get rid of these!!!
http://cgi.ebay.co.uk/301220217757
Pat_T
posted on 24/6/14 at 08:41 PM Reply With Quote
Front brakes
Front brakes - AP Racing twin pot calipers, 282mm discs, pads and hoses all for sale. The discs and pads are pretty much brand new - around 100 miles on only!
£250 posted for the lot. Be quick these will go very fast
cheers
here's pictures:
ceebmoj
posted on 24/6/14 at 09:06 PM Reply With Quote
did you replace the disks or just the pads 100 miles ago? The disks look like they are MMC check them with a magnet. If they are MMC some one on seloc will been keen to get hold of them.
[Edited on 24/6/14 by ceebmoj]
Pat_T
posted on 24/6/14 at 09:20 PM Reply With Quote
both, but they are just standard steel discs...
Pat_T
posted on 25/6/14 at 07:35 PM Reply With Quote
Koni dampers & Eibach springs
S1 Elise Koni Dampers with Eibach springs. Fully functional but could maybe do with the springs removing and repainting/powdercoating for a cosmetic tidy up. If it was me I'd fit new bumpstops at the same time but apart from that they are ready to go back on! No leaks from any of the dampers, no cracks on the springs. These were purchased as a full car set and have an August 2009 manufacture date. Estimate 4 years and 20,000 miles on them.
£110 for the set collected from LE10 or plus £12 for UK postage
£100 for the set collected from LE10 or plus £12 for UK postage
Pat_T
posted on 26/6/14 at 07:38 PM Reply With Quote
brakes and dampers/springs on ebay
S1 Lotus Elise Exige front brake calipers, hoses, discs &' pads (nearly new!)
S1 Lotus Elise Exige Genuine Koni Shock absorbers with Eibach Springs
thanks
Pat_T
posted on 29/6/14 at 06:08 PM Reply With Quote
exhaust manifold
on ebay: 99p start, no reserve!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=301229682026
cheers
Pat_T
posted on 16/8/14 at 07:56 PM Reply With Quote
me again
Steering wheel.
Standard factory Elise wheel. 310mm outer diameter. Nice and lightweight. No boss or horn centre button included but steel base section looks easy to mount off for a locost project. Centre section is removable.
£17 posted
Anti Roll Bar clamping mounts.
2x Elise front anti roll bar clamps. These are nice extruded aluminium pieces that would be ideal for a Seven build (front or rear). You could use the standard Elise bushes and have your own bar fabricated to suit.
£15 posted
cheers
Pat_T
posted on 6/9/14 at 06:55 PM Reply With Quote
steering wheel sold.
Anti Roll bar clamps on ebay - http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=301305892048 - 99p start, no reserve!
Fuel pump and driveshafts/CV joints available soon. Possibly a full set of aluminium uprights too!
cheers
Pat_T
posted on 28/9/14 at 12:55 PM Reply With Quote
STACK instruments and slave cylinder
STACK instruments/all-in-one dash:
These do everything in the one unit as you can see. Speed, revs, warning lights, headlights, indicators, fuel level, coolant temp, odometer, handbrake, engine check light.
I believe they are getting pretty rare now so I will be taking offers on this for a few days before I set a price! Post here or U2U me.
AP Racing Clutch slave cylinder:
Perfect working order, however split in the rubber boot as pictured. Can probably buy replacement boot separately. Nice and lightweight option for any FWD derived lever operated clutches in middy locosts?
£13 posted
cheers
Pat_T
posted on 30/9/14 at 09:09 PM Reply With Quote
Dash sold instantly.
Offers on the slave cylinder before it goes on ebay?
Any interest in the aluminium uprights? not too sure what they are worth at the moment.
Will also have the fuel pump, and possibly the fuel tank for sale soon...
Pat_T
posted on 12/10/14 at 10:28 AM Reply With Quote
K-series engine mount - £22 posted
Pat_T
posted on 16/11/14 at 07:08 PM Reply With Quote
standard S1 Elise radiator and fan available, can sort pics on request
Pat_T
posted on 17/11/14 at 06:45 PM Reply With Quote
rad
core = 600 x 300 x 33mm
overall = 680 x 340 x 80mm (inc fan)
spigots = 30mm ID
fan = 300mm diameter
tiny bit of delamination on the fins in one corner but the rad doesn't leak and is structurally fine.
£32 posted
Pat_T
posted on 13/12/14 at 08:25 PM Reply With Quote
offers for the rad & fan before it goes in the bin? (collection preferred)
still got the clutch slave cylinder.
soon will have full set of aluminium uprights, and possibly the steering rack too...
Pat_T
posted on 9/1/15 at 10:00 PM Reply With Quote
gearchange mechanism, tower and cables
Should be suitable for any Middy with a FWD derived gearbox. Nice and light (around 2.0kg everything you see)
open to sensible offers. collection preffered LE10
cheers
Pat_T
posted on 13/1/15 at 10:07 PM Reply With Quote
aluminium footwell divider
comes with footrest for clutch foot.
only 699grams.
£28+postage or collection from LE10
theduck
posted on 13/1/15 at 10:23 PM Reply With Quote
Any idea on price for dash?
[Edited on 13/1/15 by theduck]
JC
posted on 14/1/15 at 03:56 AM Reply With Quote
For some reason I can't see the photos of the gear change stuff - might be an iPad issue...otherwise might be interested if I can see it!
Pat_T
posted on 14/1/15 at 12:48 PM Reply With Quote
Sorry, not sure what is going on with the pics, it might be beacuse I'm hosting them on another lotus forum. When I get home this evening I'll re-upload them onto here for you
<<  1    2    3  >>
