40inches
posted on 1/5/14 at 02:30 PM |
Changing to Freelander diff?
What is involved? Would rather not have to get (yet another) propshaft made.
Replace Freelander input flange with a Sierra compatible one?
Are drive shafts available to suit Sierra hubs, or hybrid's needed?
adithorp
posted on 1/5/14 at 02:39 PM |
You'll need hybrid shafts but the good news is the Freelander and Sierra push-in inner joints have the same splines so can be swapped over.
BaileyMorris should be able to swap the coupling/saddle on the rear UJ to convert the Sierra fitting to Freelander.
http://jpsc.org.uk/forum/
Paul Turner
posted on 1/5/14 at 02:43 PM |
Why swap.
Nothing wrong with the Sierra diff. Been using one in mine for 21 years and never had an issue. It will take large amounts of power and various
LSD's are widely available. Got a 3.92 in at present but I have a spare case set up with a 3.62 and a brand new 3.92 CWP should I need them.
Seems like you are going to spend a large amount of money for no benefit whatsoever.
matt_gsxr
posted on 1/5/14 at 05:35 PM |
quote: Originally posted by Paul Turner
Why swap?
3.2
posted on 1/5/14 at 07:26 PM |
And 7kgs lighter iirc.
bi22le
posted on 1/5/14 at 07:58 PM |
And more common \ cheaper in the long run if things do go wonkey.
Please read my ring story:
Doctor Derek Doctors
posted on 1/5/14 at 09:18 PM |
I have a prop' that's type 9 to freelander kicking about, you could cut the rear flange/UJ off and weld it onto your existing one. If you
can collect from Spondon (nr Derby) you're welcome to have it. Also you can have a look at the installation of my freelander diff if you want.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
posted on 1/5/14 at 09:21 PM |
Also you can still get hold of Westfield Megablade driveshafts that do freelander to Sierra mating, that's what I use.
www.t89.co.uk
callan@t89.co.uk
sparkyj83
posted on 2/5/14 at 05:54 AM |
My mac#1 worx use's the freelander diff talk the boys at mac as they custom make drive shafts no welding things together .
