Author: Subject: Headlight bracket
RichB
posted on 20/5/14 at 12:03 PM Reply With Quote
Headlight bracket
Hi
Please excuse me if this is too noddy for most!
Can anyone send/post a photo of how their headlight brackets attaches to their chassis please? There are lots of very nice pictures of varous designs but all from the outside.
Ideally I would want to fabricate without welding as I don't have the gear or experience. I kind of like the idea of a carbon bracket but this build has already taken too long! The 'best' solution would actually be to find one ready done (it's got to that level now).
Rich
CosKev3
posted on 20/5/14 at 02:49 PM Reply With Quote
Pretty sure 99% will be welded straight to chassis.
Can only think of very early MK indys that had a light bar that had both headlights bolted to it and was bolted to the top of both top chassis rails.
SteveWallace
posted on 20/5/14 at 03:50 PM Reply With Quote
This is how I did mine. Sorry that I don't have a better picture of them on the car. The second picture shows the cardboard template that I made up. All I did was then cut and bend the metal to the right size and take it to my local iron gate maker to have them welded up. They bolt to the front cross braces in the engine bay and the wiring runs through the steel tube.
radiator hoses
radiator hoses
carboard headlight mount
posted on 20/5/14 at 04:14 PM Reply With Quote
Bit of bar, couple nuts and bolts...
RichB
posted on 20/5/14 at 07:25 PM Reply With Quote
Thanks for the replies guys.
Steve that reminds me that the Luego ones looked like that.
I'm tempted by the simplicity of the lighting bar solution.
Just goes to show how many ways there are of doing something simple!
Rich
SteveWallace
posted on 22/5/14 at 10:33 AM Reply With Quote
Rich
That's where I got the idea from. I would have used a simple bar, but as you can see from the first photo, the radiator plumbing would have got in the way. Don't forget that whatever solution you go with, you will need to make sure that it meets the IVA radius requirements.
