Author: Subject: Zetec crank sensor holder, 1800 Flywheel etc
pigiron
posted on 6/8/14 at 04:29 PM Reply With Quote
I'm converting a 2.0 Silvertop auto to manual rwd so require the alloy crank sensor holder from a manual.
Also looking for a 1.8l flywheel.
pigiron
posted on 13/8/14 at 01:25 PM Reply With Quote
Found sensor holder.
Still need flywheel.
Cheers.
scotty g
posted on 25/8/14 at 06:35 PM Reply With Quote
I have a 1.8 flywheel but i'm down in kent so not sure if that's any use to you matey?
baz-R
posted on 27/8/14 at 12:48 PM Reply With Quote
i have a 1800 cvh flywheel thats been machined to fit a zetec for a rwd conversion with newish clutch (type9) but you woud need to add a trigger to front pully.
the idea is it makes an easy rwd conversion (std clutch) and is ligter than a zetec flywheel
im in devon
[Edited on 27/8/14 by baz-R]
whitestu
posted on 27/8/14 at 01:23 PM Reply With Quote
I use a 1.8 CVH flywheel and it is much lighter than a Zetec 1.8 at about 6.5kg. I think the Zetec is about 9kg.
Adding a front trigger is easy enough.
Stu
pigiron
posted on 3/9/14 at 11:27 AM Reply With Quote
Thanks for the replies chaps, now sorted.
