Author: Subject: MIG Welder faulty?
mookaloid
posted on 10/10/14 at 07:54 PM Reply With Quote
MIG Welder faulty?
My MIG (clarke 151) has started 'pulsing' so instead of a steady bzzzzzzzzzzzzzzzzzzzzzzz it goes bzz bzz bzz bzz bzz ....
Is it faulty? can it be fixed? What is the likely problem?
anyone seen this before?
M
posted on 10/10/14 at 08:04 PM Reply With Quote
Does it pulse even before you strike an arc? Probably motor control board, duff capacitor or solder joint would be my guess.
Andy S
posted on 10/10/14 at 08:23 PM Reply With Quote
Would think its one of the main power diodes in the rectifier pack - just google mig rectifier failure diode replacement etc - the pulsing will likely be just half wave being rectified.
posted on 10/10/14 at 08:33 PM Reply With Quote
Heart failure.com
arrow-engineering
posted on 10/10/14 at 09:55 PM Reply With Quote
take the side cover off, and watch the wire closely over the wire feed wheel while you press the trigger, sometimes the wire slips every revolution due to the ridges in the wheel being clogged or worn away. start simple. might need a new wheel or the tensioner adjusting up a touch
mookaloid
posted on 11/10/14 at 08:29 AM Reply With Quote
Thanks chaps, a few things to check there. I'll report back.
owelly
posted on 11/10/14 at 09:18 AM Reply With Quote
Are you using clean wire? If there's any rusty dust in the torch liner, it can cause this pulsing. Also, folks use extension leads that are too feeble, which can also cause it.
http://www.ppcmag.co.uk
