posted on 18/10/14 at 06:33 AM |
Pinto running problems
Just broken down lol! Symptoms are hard to start and after 5 mins it starts to backfire and gradually dies. I'm thinking the timing is out. Do
those symptoms sound likeiit's too advanced or retarded? And which way to turn the dizzy to correct it?!
Cheers!
posted on 18/10/14 at 06:48 AM |
Sounds more like a fueling problem or an overheating coil.
Carb or injection?
What type of ignition.?
posted on 18/10/14 at 07:02 AM |
Fuel pressure gauge says 2 psi which does sound low. It's the old distributor with a lumenition fitted, and dellortos.
snapper
posted on 18/10/14 at 07:04 AM |
This will get you started if ignition is out just swing the dizzy a little either way till you get a smooth idle then use a timing light
[URL=http://s750.photobucket.com/user/snapperpaul/media/f3fbcbf4.jpg.html]
[Edited on 18/10/14 by snapper]
I eat to survive
I drink to forget
snapper
posted on 18/10/14 at 07:08 AM |
having trouble uploading the other diagram
It's similar but with front pully and timing mark
So on posted diagram substitute cam belt drive woodruf key for outer pully TDC mark and timing indicator on alloy casing.
This sets the spark static to 0 degrees you then swing the dizzy so spark shows 8 degrees or a little more with a timing light
I eat to survive
I drink to forget
posted on 18/10/14 at 07:41 AM |
Strange thing is that we did the timing a few weeks back, and it ran loads better. Now the battery is half flat though, which could be the problem.
But it's the popping from the carbs that made me think timing again.
Does 2 psi sound low?
Cheers!
smac
posted on 18/10/14 at 07:56 AM |
Is it a mechanical pump? I have a couple if you want to try another
posted on 18/10/14 at 08:17 AM |
It's an electric one in the back. Thinking of it, I bought the car as a non runner and one of the things wrong was the fuel pump sticking and
blowing its fuse, so this is definitely a suspect part!
Daverog
posted on 18/10/14 at 08:41 AM |
Popping back through carbs can also be a symptom of weak mixture. Fuel pump could be a suspect as you said.
posted on 18/10/14 at 08:54 AM |
It's idling fine and revving well now, so quite likely that is just running out of fuel after a while with the throttle open. Cheers for the
help guys. I think I'll get a bike carb pump off eBay.
Cheers!
smac
posted on 18/10/14 at 11:12 AM |
mine always ran ok on the mechanical pump and that was with twin 45s
posted on 18/10/14 at 12:03 PM |
First test is check the fuel tank vent is letting air back into the tank.
posted on 18/10/14 at 04:32 PM |
I charged the battery up, and it ran fine. Had a nice little blast in fact. Did snap a cycle wing mind...
I guess it just needs a rough shake down and some basic testing. Cheers for all the help.
