Author: Subject: R1 start wire
CosKev3
posted on 21/10/14 at 09:57 AM Reply With Quote
R1 start wire
My R1 eng start wire needs -12v to start the engine, I want to use the sierra ign barrel to start the engine.
Am I right in thinking to do this, as the start position of sierra barrel puts out a +12v, I need to wire in a relay that will switch on the required -12v to start eng?
Or any other way easier I'm over looking?
Cheers.
owelly
posted on 21/10/14 at 10:38 AM Reply With Quote
-12v? How will you find that?
http://www.ppcmag.co.uk
Johneturbo
posted on 21/10/14 at 10:56 AM Reply With Quote
I though the R1 was just a wire to ground to start it blue/white if memory is correct
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 21/10/14 at 11:42 AM Reply With Quote
I did exactly this on my R1 engine and sierra ignition barrel.
The start button on the R1 loom just makes a circuit. Nothing else.
All I did was wire in a relay which just made a circuit when I turned the key, thus simulating the start button being pushed.
This was the diagram I used:
adithorp
posted on 21/10/14 at 12:24 PM Reply With Quote
The R1 start is triggered by earthing the start wire (blue from memory). I'm guessing by "-12v" you mean earth.
To use the sierra ingnition barrel wire that to trigger a relay that switches to earth as you described.
http://jpsc.org.uk/forum/
CosKev3
posted on 21/10/14 at 03:01 PM Reply With Quote
Yeah that whats I meant!
Cheers for confirming.
Thanks for your helpful input, always one cocky knob ain't there...........
