Author: Subject: Wrong flasher unit ? possibly ?
907
posted on 22/10/14 at 04:08 PM Reply With Quote
Hi All,
Todays IVA job was to wire up the indicators, or so I thought.
I can't remember when I bought the flasher units, or where from, but I think I've got a problem.
One is marked "21w x 4" and the other "21w x 2 +5w".
Didn't get as far as the "x4" ( hazard ? ) as the "x2" only does an odd flash then stays on constant.
The indicators are as follows:-
Front - 21w normal bulb.
Side rep - small wattage bulb.
Rear - LED units.
The LED units have a resistor wired in, but I'm not sure on thinking about it which part of the light it's wired to.
Do I need a different flasher unit ? If so, what one ?
Do I need to check and possibly re-wire my back lights ?
Should I admit I'm more likely to be struck by lightning than get the wiring finished and working ?
Cheers in anticipation
PauL G
alternative needed, I think
luke2152
posted on 22/10/14 at 05:11 PM Reply With Quote
I'm sure someone can answer based on the numbers but wouldn't be easier to just test it....
However if you do need another one I'd suggest a solid state one as they work with all wattage bulb from tiny LED's to big standard ones and will always go at the right speed.
peter030371
posted on 22/10/14 at 05:24 PM Reply With Quote
Get a solid state relay and ditch the LED resistors
avagolen
posted on 22/10/14 at 06:18 PM Reply With Quote
I agree with the previous suggestions.
Get a solid state flasher. No need for any resistors.
Mix and match LED and lamps.
Only downside is no rapid flash for failed lamp.
907
posted on 22/10/14 at 06:46 PM Reply With Quote
Thanks for the advice.
Would this be suitable ? Do I need one for indicators and another for hazards ?
If not suitable can anyone recommend a different one (or two)
eBay Item
Paul G
Jon Ison
posted on 22/10/14 at 06:51 PM Reply With Quote
That's the unit I've had on my car for years.
luke2152
posted on 22/10/14 at 06:55 PM Reply With Quote
You only need 1 for hazards and indicators but you need a dual switch for the hazzards to keep the left and right circuits seperate (otherwise 4 ways will come on every time you indicate)
gremlin1234
posted on 22/10/14 at 07:00 PM Reply With Quote
to test you could try standard bulbs.
edit, check the earth on the flasher relay
[Edited on 22/10/14 by gremlin1234]
907
posted on 22/10/14 at 07:57 PM Reply With Quote
Many thanks everyone.
I've just ordered the one in my link. Should be here Friday.
Trouble is I'm waiting for a work delivery so today and tomorrow are my weekend.
Will be working Saturday and Sunday to make up.
O the joys of self employment.
Thanks again
Paul G
