Author: Subject: ford seirra rear caliper sliders
mk85
posted on 18/11/14 at 10:05 PM Reply With Quote
U have a set of new rear calipers but am missing the slider brakets and bolts. Any one have spare ones or kniw where I can buy new sets thanks
Madinventions
posted on 19/11/14 at 12:56 AM Reply With Quote
You could try giving Bigg Red a call; they seem to have loads of bits available.
http://biggred.co.uk/onlinestore.php
Ed.
View my band website:
http://www.shadowlight.org.uk
mcerd1
posted on 19/11/14 at 08:14 AM Reply With Quote
they can be surprisingly hard to find without buying another new caliper as well - I got some form the local scrapyard in the end
these are the same as the mk3 Granada and the scorpio's so that give you a bit more choice, but make sure you get the right one as there are 2 kinds of slider bracket - one for vented discs and one for solid discs
bigg red will have new slide pins and rubbers you need and a bit of Electrolysis (linky) can clean up the castings so you don't worry about the state they are in too much as long as they aren't bent and the threads aren't stripped
