Author: Subject: Duratec to Type 9 Bellhousing Bolts
davidimurray
posted on 22/11/14 at 06:52 PM Reply With Quote
In preparation for starting on my engine swap just been checking bits that I need. I assume that the existing bolts from the pinto bellhousing to type 9 main body can be reused with a new bellhousing ?? (I,e, the gearbox to bellhousing bolts)
Can anyone confir as it will save me getting stuck when I get that that bit!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
edthedrummer
posted on 22/11/14 at 07:20 PM Reply With Quote
Not sure mate, have a feeling the standard bolts are too short with the aluminium bellhousing. Am sure I need to replace with longer on mine, but the engine and box are fitted in the car at the movement temporarily so I can't check for you
Thatcher
posted on 22/11/14 at 08:04 PM Reply With Quote
Will measure mine tomorrow for ya as mine are just on a shelf.....
big-vee-twin
posted on 22/11/14 at 09:16 PM Reply With Quote
I had to buy longer bolts the alloy bell is thicker.
You will also need this one too, to stop your layshaft moving.
[img] Layshaft retaining bolt
[/img]
[Edited on 22/11/14 by big-vee-twin]
http://www.triangleltd.com
davidimurray
posted on 22/11/14 at 09:18 PM Reply With Quote
Thanks Tony - did you get yours with the bellhousing?
Big Vee - thanks for confirming - I notice RWD sell these - http://www.rwdmotorsport.com/fine-cap-head-bolts-4.html
Thatcher
posted on 22/11/14 at 09:29 PM Reply With Quote
Na I bought them from a industrial hardware factors but bought them twice as the first ones were too short ggggrrrrrr......
big-vee-twin
posted on 22/11/14 at 10:30 PM Reply With Quote
Got mine from Namrick.
