Author: Subject: Golf 1 donor car
Marty
posted on 23/11/04 at 04:00 AM Reply With Quote
Golf 1 donor car
Does anyone know of a mid/rear engined car built from a front wheel drive vehicle (apart from a Mini - I have read the mail).
I have a mechanically sound Golf 1 in my garden that has a badly rusted body due to the high humidity and salt air here in Richards Bay, South Africa. and it seems a shame not to make use of it.
Rorty
posted on 23/11/04 at 04:22 AM Reply With Quote
Marty, welcome to the online residential facility for the automotively depraved.
If you look down through some of the Mid Engine posts, you'll come across such characters as AlanB, sgrabber, kb58 and others (sorry guys, I can't remember all the names without browsing...doesn't mean you're any less important!).
They have used transverse front wheel drive engines in the "right" location.
From a driveline aspect, the Golf would be a good donorand the engines can be quite respectable too.
Cheers, Rorty.
sgraber
posted on 23/11/04 at 04:51 AM Reply With Quote
Marty, If you think you can build a mid-engine sports car out of an old Golf, you are crazy.
Welcome to the club! The Bolwell Ikara was an early 80's middy built using the Golf as a donor. Dominic, who is building a middy in Australia has the following page with more information. http://members.optushome.com.au/gecko/ikara.html It was a great little car that was just a bit ugly (IMHO).
So I guess the key thought here is that you should start stripping that donor ASAP.
Graber
PS - click on my www button below to visit my site.
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
ned
posted on 23/11/04 at 09:41 AM Reply With Quote
take a look at the sylva mojo, fwd drivetrain at the back.. www.sylva.co.uk i think..
Ned.
beware, I've got yellow skin
Alan B
posted on 23/11/04 at 12:43 PM Reply With Quote
Marty,
You are one sick and twisted individual.
WELCOME
<manly group hug>
derf
posted on 23/11/04 at 02:22 PM Reply With Quote
If I were to build a middy there are a few engine choices I would go with, my main choice is a honda b16 or b18, mainly due to the aftermarket support. Right behind that is Ford's Zetec (I've dyno'd mine at 266 Hp at the wheels with 12 psi on a stock engine, good fuel management is the key to a long engine life. Along side Ford's Zetec is Toyota's ZZTTII (?) (from the new model Celica, also used in various other Toyota 4 Cyl's), I just love the new technology they put in it.
Anyway The Golf engine is a good compromise between all of them. The stock internals are fairly stout, and will hold their own in a heavy use environment, the aftermarket support is abundant (not sure about SA, but here in the US it is), it has been proven as a winner time and time again in SCCA competition, and at the time it was a fairly advanced (technologically) engine. Overall it's a good engine right down the middle.
TheGecko
posted on 24/11/04 at 07:28 AM Reply With Quote
Marty,
Welcome to the insanity Thanks Steve, for pointing Marty to my Ikara page. It reminded me that I need to shift that page from my old Optus web space to my new host. At the same time I should restore all of the scanned magazine pages that used to be linked from that page before I ran out of space.
As Ned points out, the Sylva Mojo is a perfect example of what you're proposing. Neither the engineering or styling of the Mojo really do it for me but, each to their own.
Other examples include the GTM Libra & Spyder (here) and the Car Craft Cyclone (sadly gone now).
Best of luck,
Dominic
violentblue
posted on 25/11/04 at 07:58 PM Reply With Quote
I'm actually considering throwing my G60turbo in the back of my golf. just so I have better traction at the track.
and if i get really stupid I could add a matching engine in the front.
a few pics of my other projects
DarrenW
posted on 26/11/04 at 10:31 AM Reply With Quote
Dubsport did a couple of twin engined Golfs a while back. Got some fantastic write ups in mags.
link - http://www.dubsport.com
The problem with Golf engine feeding rear wheels is finding or mating suitable gearbox to it. Not impossible just needs sussing out. 1.8 16V was always a good competitor to VX XE. VR6 is known to be a bit heavy though, was always a bit of a problem in a Mk1, dubsport had a novel way of overcoming this. If you manage to get some internal pics you will see the gear linkage - could be interesting.
A guy round the corner from me is building Mojo2 with Honda 2.0 Vtec (and moddified with throttle bodies!!!). Gear linkage was a nightmare but the managed it inhome garage. Had to the link under the engine right to back of car and then into gearbox. Shafts work through bearing blocks.
HTH
Darren.
Rorty
posted on 26/11/04 at 01:01 PM Reply With Quote
Shafts normally only work properly if there is a line-of-sight between the connections. Bends, bearings etc will leave it very spongey.
A line-of-sight rod works best, otherwise cables with quality fittings work extremely well. In my experience that is.
Cheers, Rorty.
sgraber
posted on 26/11/04 at 03:35 PM Reply With Quote
Shifter mechanism.
You need to take a good read of Kurt Bilinskis Mid-Engine Mini page. http://www.kimini.com/Diaries/Pre2003/index.html
Follow that link and look about 2/3 way down the page. October 2002 through November 2002 dedicated to solving the shifter issue. But he did a great job and one worth copying I think. (Hope that's ok Kurt!)
Steve Graber
violentblue
posted on 26/11/04 at 05:21 PM Reply With Quote
I'll be using the stock g60 cableshift box.
but if you wanted to go longitudaly mounted you could use a Fox tranny or another Audi variant.(fox box will do, but you'll need to baby it)
the 5000T box would be perfect, except it has a larger bellhousing pattern (same pattern but larger)
Rorty
posted on 26/11/04 at 08:51 PM Reply With Quote
Originally posted by sgraber
Shifter mechanism.
Kurt mentions "about 1/8" of backlash" (however much that is ), but is satisfied with the final result.
If you're going this route, buy only the good quality cables, as sloppy ones will reveal small amounts of backlash which is no better than a convoluted rod gear change.
The top quality cable manufacturers use very high tech materials and processes to eliminate backlash, and it's worth paying the extra for the benefits.
Kurt, if you read this, what brand of cables did you use? You mentioned Cable Craft at the start of the sequence, but I suspect that was like calling spherical rod ends "Heim joints" or "Rose joints".
BTW, why does nobody call them "Aurora joints"? I think Aurora are the world's leading spherical joint manufacturer.
Cheers, Rorty.
Marty
posted on 27/11/04 at 05:21 AM Reply With Quote
Golf 1 donor car
I must thank everyone who replied to my suggestions that I might be able to turn my rusting Golf 1 into an interesting mid engined car. Everyone's humour greatly appeals to me!
I am nervous about such a project as I know how much work is involved. Although I have been retired for a couple of years I still don't know where the time goes and how I ever found time to go to work for almost fifty years I don't know.
The web site is so large that it takes hours on line to read even parts of it.Where should I look to find a basic space frame design?
MrFluffy
posted on 27/11/04 at 11:22 AM Reply With Quote
Because according to mr stanniforths chassis book, the Rose company was the main importer/distributer of spherical joints in england and it became a generic term a bit like a hoover for a vacumn cleaner
Rorty
posted on 27/11/04 at 11:37 AM Reply With Quote
Originally posted by MrFluffy
... the Rose company was the main importer/distributer of spherical joints in england and it became a generic term ...
Yes, I grew up with "Rose joints". In my innocence, for years I asumed they were called rose joints because they resembled roses.
And Philip's head screws...
Cheers, Rorty.
posted on 27/11/04 at 01:25 PM Reply With Quote
There's a reason for that one.
kb58
posted on 27/11/04 at 05:23 PM Reply With Quote
"Cablecraft" is the name of the company, they're in Los Angeles, California. I was very happy with their product and service other then the issue I pointed out. If the cable is not curved in application, there is no backlash, none. The problem arises when the cable is bent, say, 90 degrees. There is an inner and outer subassembly that aren' really connected. That is, the inner actual cable and cover rides inside the outer covering. So there is a bit of clearence between the two. With the assembly bent, it allows the inside sub-assembly to move sideways, that is the source of the backlash. If it bugs me enough someday I can maybe inject something through the outer cover to lock the inner sheath in place, but it hasn't been a problem in "all" my testing (two laps around the block...)
[Edited on 11/27/04 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Rorty
posted on 27/11/04 at 09:01 PM Reply With Quote
.... the inner actual cable and cover rides inside the outer covering. So there is a bit of clearence between the two. With the assembly bent, it allows the inside sub-assembly to move sideways, that is the source of the backlash.
I'm glad you pointed that out. I've been recommending Cablecraft as one of the sources of cables to mu US customers for years, based purely on their notoriety.
I've never had any complaints from my customers about sloppy gear changes, so eitheer they didn't end up purchasing their cables from Cablecraft, or the backlash is too insignificant to matter.
In Australia, I use two different products: one is locally made, and the other is imported from the US. The US version is very expensive and IIRC, comes from Uflex.
They really are the answer to remote control; everything from gear linkages to throttle cables to steering linkages.
Cheers, Rorty.
fatfranky
posted on 4/12/04 at 01:18 PM Reply With Quote
HI Marty
If you fancy going the VW route then it could be worth considering a newer Golf. Mk2 Golfs used an engine mounting subframe which of course could simply be bolted to your chassis, Mk3 Golfs used a very similar arrangement and some models used a cable change gearbox, making the gear linkage a bit easier. Mk3's are also about 3" wider (wider track) if that suits you, as an alternative you could also consider the Passat with the transverse engine as it was basically a "big Golf" in mechanical terms
sgraber
posted on 4/12/04 at 07:53 PM Reply With Quote
I think our friend already has an MKI golf that he wants to use as a donor.
Steve Graber
kango
posted on 9/12/04 at 06:34 PM Reply With Quote
In SA we have a huge following for the Golf and performance parts are plentyfull.
I have the same idea for my next car ...so has anybody done it?
