New Topic New Reply
Author: Subject: 51mm steel tube offcut
Dooey99
posted on 6/12/14 at 05:40 PM Reply With Quote
has anyone got any off cut of 51mm steel pipe/tube? im only after abit 70mm long and the smallest bit i can find is 1m and just seems like a waste. i need to lengthen my roll bar hoop i acquired.
Many Thanks
Less weight more speed, more power more speed
If in doubt, give it a clout
theprisioner
posted on 6/12/14 at 06:51 PM Reply With Quote
Scaffold pole?
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
loggyboy
posted on 6/12/14 at 06:57 PM Reply With Quote
Sounds dangerous
Mistral Motorsport
scutter
posted on 6/12/14 at 09:37 PM Reply With Quote
Can you wait until monday when I can check the workshop?
Dan.
Dooey99
posted on 7/12/14 at 12:12 AM Reply With Quote
i can wait thanks dan. 51mm is a pretty standard exhaust size aswell so i may be able to try and find an off cut of new ehaust
cliftyhanger
posted on 7/12/14 at 07:23 AM Reply With Quote
Please do not tell me you would use exhaust tube in a roll bar. If you are prepared to do that why fit one at all???
Dooey99
posted on 7/12/14 at 11:17 AM Reply With Quote
exhaust steel was an option just to get the apprearance right. i have some steel to sleeve inside it which is 4mm thick so it would have enough strength the exhaust steel was just so it looked the same if you get what i mean?
scutter
posted on 10/12/14 at 02:40 PM Reply With Quote
Sorry, I only have 45mm cage tube.
ATB Dan.
steve m
posted on 10/12/14 at 07:05 PM Reply With Quote
when I extended my Caterham roll cage, I had inserts made of mild steel, that were the inner measurement and outer, so gave me inner strength, plus the outside , they were an interference fit, and araldited and c pinned
steve
Dooey99
posted on 21/12/14 at 05:54 PM Reply With Quote
good thinking steve, i have access to a metal lathe so if i can find a fairly heavy piece of 51mm steel then i could machine the ends down to sleeve the ends. anyone help me out with a heavy piece of 51mm steel pipe?
Brian R
posted on 21/12/14 at 10:22 PM Reply With Quote
I'll have a look at work in the morning. Got allsorts in the rack.
Fred W B
posted on 22/12/14 at 07:52 AM Reply With Quote
If it's just a trim piece you can adjust the diameter of a piece of tube that is close by slitting it lengthways and cutting out or inserting a bit as necessary.
Brian R
posted on 22/12/14 at 08:11 AM Reply With Quote
All I can find is 50 x 1.5mm ERW tube and 48.3 x 3mm hollow section. I can chop a bit of those off and send them if either are any good?
Failing that I have some 2" EN3B bright round bar which is 50.8mm. I can bore a piece of that out for you if you like?
New Topic New Reply
