Author: Subject: Differences between 1.18l and 2l Pinto
davidimurray
posted on 11/1/15 at 06:24 PM Reply With Quote
What are the differences between a 1.8 and 2l Pinto.
Block?
Cylinder Head?
Crank?
Con Rods?
Flywheel?
Camshafts?
I am guessing that the auxiliaries like cam cover, pulleys, sump, water pumps etc are all the same?
Not had any interest in my 1800 Pinto that has come out of the car so considering breaking it for parts.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
steve m
posted on 11/1/15 at 06:28 PM Reply With Quote
200cc
austin man
I think the 1.8 is more derived from the CVH engine with the distributor at the front of the engine so may not have the same ancillaries
steve m
posted on 11/1/15 at 06:29 PM Reply With Quote
joking apart, I doubt the block or crank or conrods are the same
the other stuff maybe
davidimurray
posted on 11/1/15 at 06:39 PM Reply With Quote
I think your thinking of the CVH - the 1.8 Pinto has the distributor in the same location as the others. According to Burtons the 1.8 was a development of the 1.6 using the same rods.
Wikipedia comes up with -
code:
At the beginning of 1984 Ford Pinto engine displacement range switched from 1.3/1.6/2.0 to 1.6/1.8/2.0. The newly introduced 1.8 L engine used the 2.0 L crankshaft, so in order to uniform engine parts for the whole range after dropping the 1.3 L — the 1.6 L was redesigned to also take the 2.0 L crankshaft which had a 76.2 mm (3.00 in) stroke.
The block is definitely different.
[Edited on 11/1/15 by davidimurray]
snapper
posted on 11/1/15 at 08:34 PM Reply With Quote
There are 2 x 1.8 Pinto's
The early version was built to defeat a company car tax bracket that made the 2.0L the top tax bracket
The Pinto series had capacities of 1.3, 1.6, 1.8, & 2.0L (2.3 in the USA but different block and head)
All Pinto's had the same crank
All pintos had the same block size but the block castings were different so you can't bore a smaller casting much past the over bore limits
There was an Eco 1.8 that had a different crank & stroke
You can put a 1.6 head on a 2.0l but compression ratio is to high and now the injection head is prefered as it flows better due to a better inlet port short side turn and a slightly better port angle.
I eat to survive
I drink to forget
snapper
posted on 11/1/15 at 08:40 PM Reply With Quote
The 1.8 has some usable parts but cam, head, block are not worth anything
The first upgrade for any Pinto powered car is the 2.0L followed by the injection head
There is no point what so ever trying to make a lower capacity engine match or exceed the power of an identical sized bigger capacity engine unless you are racing in a capacity restricted formula
I eat to survive
I drink to forget
davidimurray
posted on 11/1/15 at 09:06 PM Reply With Quote
Cheers - I've skipped that stage and gone straight to the Duratec
Memphis Twin
posted on 11/1/15 at 10:44 PM Reply With Quote
The 1.8 (185 block) crankshaft and connecting rods are identical to the 2.0l. The 1.8 has a smaller bore at 86mm, but the stroke is the same at 76.95mm. The 1.8 crank even has 2.0 stamped on it, so do not throw it away as it's a good crank for engine builders of 2.0 litre Pintos. Also, they have usually not been reground as most people just stick in a larger engine rather than trying to improve the 1.8.
According to Ike Flack (engine builder of great repute) the 185 block will bore to 2.0l as all the castings are the same, just with more machining out for the 2.0l but I cannot confirm or deny this.
SteveWalker
posted on 11/1/15 at 11:45 PM Reply With Quote
Back when I had a Sierra 1.8GL, E-reg, with a Pinto Engine, the 1.8 engine even had 2.0 cast into the block!
BaileyPerformance
posted on 12/1/15 at 09:04 AM Reply With Quote
Your thinking of the 1800 CVH, there is a 1800 pinto too. Very little difference between the 1800 and 2000 pinto.
The 1800 head has smaller combustion chambers than a 2000 so can be useful to use on a 2000 bottom end to raise compresson.
Thr cams are interchangeable
davidimurray
posted on 12/1/15 at 10:20 AM Reply With Quote
Thanks everyone - mine is a late - 1987 185 block - had hoped to sell as a complete unit as seems a shame to break it. If anyone wants any bits from a low mileage Pinto let me know!
