Author: Subject: 99 Hayabusa no spark.
PorterBespoke
posted on 17/1/15 at 02:04 AM Reply With Quote
Hi all, I've had a good search through the forum and can't find what I'm after - I'm doing the wiring a '99 Hayabusa engine in a rally car, I have put the necessary resistors in (150 ohm in ignition, 68k ohm in TOS, am running a clutch switch and have jumped the side stand switch etc.) Everything lights up as it should, the fuel pump primes, and the engine turns over, but I am not getting any spark.
Are there any earth cables that I could be missing? Or anything else obvious that could be preventing it from sparking? I am sitting at 13v, dropping to 12.1 when cranking.
Also, I've just checked resistance across the 150 ohm resistor, and it is fine when I bench test it prior to installation, but when installed its resistance drops to 131 ohms. Any ideas on what might be causing this? And whether this may be the issue (the resistors are 1/2 watt).
Any other ideas would be greatly appreciated.
Eddie
ps. Engine is a 99 gen 1 'busa running an extreme engines dry sump kit.
CRAIGR
Contributor
Posts 2755
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 17/1/15 at 07:47 AM Reply With Quote
Cosmick on here will be your man to ask. Having said that does it have a "tilt" switch in the loom that would cut out engine if bike was on its side as on my r1 I had to silicone the switch as if in the upright position.
PorterBespoke
posted on 17/1/15 at 07:51 AM Reply With Quote
Thanks, yeah I've put a resistor in to blank the tip over sensor. I've tried to keep the loom as original as possible but that might be the problem...doing my head in!
CRAIGR
Contributor
Posts 2755
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 17/1/15 at 07:59 AM Reply With Quote
U2u Cosmick as he has a massive knowledge of busa wiring in kits, race cars etc . He's a good guy and will be happy to help i'm sure.
[Edited on 17/1/15 by CRAIGR]
PorterBespoke
posted on 17/1/15 at 08:03 AM Reply With Quote
Will do, cheers!
wylliezx9r
posted on 17/1/15 at 08:46 AM Reply With Quote
The reason the resistor is changing value in circuit is because it will be in parallel with other resistances and therefore will semmingly reduce in value (basic electrical theory). The only true way to measure a resistor is out of circuit like you already have.
George Best
minitici
posted on 17/1/15 at 10:07 AM Reply With Quote
I presume that you are not running the standard Busa key switch?
If you are running the standard key switch you would not require the resistor going to the ECU.
Normally use a 100 Ohm resistor if the key switch is removed.
