Author: Subject: duratec dual mass flywheel
melly-g
posted on 27/1/15 at 11:05 PM Reply With Quote
Its probably a long shot but does anyone have a dual mass flywheel for an 1800 duratec they want rid of? I've just got a cmax with knackered clutch so thought I should change flywheel as well. How do you tell if they are knackered? Its got quite a bit of movement in it!
samjc
posted on 27/1/15 at 11:34 PM Reply With Quote
Im breaking a mondeo if its the same i can get it off for you its from a mk3 tdci tho. Also have a duratec 2.5ltr v6 dual mass flywheel but unsure if that would fit either.
Canada EH!
posted on 28/1/15 at 12:43 AM Reply With Quote
From my experience $1800 cdn to replace dual mass flywheel in 2008 Jeep Liberty (Cherokee your side) if you can move the two parts more than 10 degrees when rotated against the springs is US. By the way this is a petrol engine, not diesel.
melly-g
posted on 28/1/15 at 07:19 AM Reply With Quote
I've got a fair bit of movement before it hits the springs! I think it s had it!
TrophyJem
posted on 28/1/15 at 07:54 AM Reply With Quote
I have one off a 2L duratec sitting on my shelf. Not sure if that's the same. I think it's a good one as the engine had only done 4k when it came off. Is got a bit of surface rust on it but nothing that would be a problem.
I'll give it a good check over if it any good to you?
jollygreengiant
posted on 28/1/15 at 10:12 AM Reply With Quote
One of the Major Clutch manufactures make/supplies a clutch kit with a replacement SOLID flywheel, and it works out cheeper than a clutch andDual mass flywheel. Worth a look/investigation Valeo I believe, yep quick search and here you go Click the linky link
A little known option as most garage go for like for like/original equipment.
Hope this helps.
JGG
melly-g
posted on 28/1/15 at 10:40 AM Reply With Quote
Don't worry about this guys I've sorted it now!
Thanks for the help.
