Author: Subject: Smiths Telemetrix Speedo & Tach
ali2992
posted on 3/2/15 at 05:50 PM Reply With Quote
looking for a smiths telemetrix speedo and rev counter, both 80mm. The rev counter should only go to 8000. I have both of these in 100mm sizes but would like the 80mm ones so will be selling them if i can find these in 80mm
turnipfarmer
posted on 3/2/15 at 06:02 PM Reply With Quote
Rally Design sell the black versions of Telemetrix under their own brand name, for a lot less money, if that's any good?
ali2992
posted on 3/2/15 at 06:08 PM Reply With Quote
ah I'll check them out, thank you. I already have the rest of the set of telemetrix (including the 100mm speedo and tach) but i need the 80mm ones for it all to fit. May be worth getting a set of the black rally design ones and selling my set of telemetrix
turnipfarmer
posted on 3/2/15 at 08:23 PM Reply With Quote
Hang on!
Just seen Rally Design have all the gauges in white as well as black, including speedo & tacho.
I know their black ones are exactly the same as Telemetrix, and the white ones certainly look very similar.
However I can't guarantee they are identical. Best to give them a bell and check first.
Type 'gauge' into the search box on the RD website & see for yourself.
ali2992
posted on 3/2/15 at 10:06 PM Reply With Quote
Are they the ones that are labeled under RMD?
turnipfarmer
posted on 3/2/15 at 10:20 PM Reply With Quote
Yes. The white tacho is their part no GW020.
They will have RMD logos on them, but they're all made by CAI Gauges (ie they're Smiths!)
