Author: Subject: FS : Ali Fuel Tank With Sump and One Way Breather **SOLD**
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 26/2/15 at 06:36 PM Reply With Quote
I have an aluminium fuel tank with a sump, fuel sender, one way breather, a good length of fuel hose and the fixing straps.
Approx dimensions : 80 x 26 x 20 cm
There is a dent in it where the straps go.
£40 delivered
[Edited on 26/2/15 by Barkalarr]
obfripper
posted on 26/2/15 at 06:43 PM Reply With Quote
I'm interested, any ideas how this compares in size to a mini van tank?
I'll have a measure up before committing though.
Dave
Andybarbet
posted on 26/2/15 at 06:54 PM Reply With Quote
I'm interested do you know if it will fit a locost ?
I will pop in the garage & try to measure my chassis.
Damn, just measured & I only have about 75cm between the chassis so I'm out :-(
Good luck, it's a bagain for someone.
[Edited on 26/2/15 by Andybarbet]
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 26/2/15 at 07:27 PM Reply With Quote
I'm surprised it won't fit - it came out of an MNR vortx
lsdweb
posted on 26/2/15 at 07:29 PM Reply With Quote
I'll have it please if nobody above has confirmed.
Ta
Wyn
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 26/2/15 at 07:43 PM Reply With Quote
Ta
Wyn
U2u sent - please send me address too.
obfripper
posted on 26/2/15 at 07:52 PM Reply With Quote
I dont think it'll quite fit in my striker, the clearance to the axle would be less than minimal without removing the rear tank mountings and pushing in tight to the bodywork.
Andybarbet
posted on 26/2/15 at 07:56 PM Reply With Quote
The Velocity has more metalwork on the back end than the MNR, the rollbar also tapers in a lot from the bottom corners up to the rollbar.
rear axle
rear axle
Gutted, ive been looking for a great deal on a tank that will fit & I need it sumped too.
Good luck with the sale :-)
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 26/2/15 at 09:10 PM Reply With Quote
SOLD !
