New Topic New Reply
Author: Subject: BOV
rdodger
posted on 31/3/15 at 08:41 PM Reply With Quote
BOV
I am about to supercharge my car again.
This time I am using a centrifugal supercharger blowing through the throttle body. I will use a recirc blow off valve I think.
I have been reading a bit about them but all the info I have found is re turbo applications.
As I understand it the BOV should be set up so seals at idle and over run, but blows off (ooh er Mrs) with vacuum and boost?
Is this ok so far?
My research then seems to show that if I am using MAP (which I will be) and or a recirc valve it can happily blow off at idle.
Any experience any one can share or advice?
dubzter
posted on 31/3/15 at 08:59 PM Reply With Quote
The supercharger system on my VW Golf R32 is a VF centrifugal charger and uses a recirculation valve, it also uses a MAF. The valve recirculates when the throttle is closed and the system is pressurised. At idle it wouldn't operate as there is no pressure in the system. It feeds back into the intake above the MAF as the air has already been metered.
Well that's how I think it operates.
_______________________
Blog
Facebook Build Thread
Haynes Forum Build Thread
Locost Builders Build Thread
bi22le
posted on 31/3/15 at 09:39 PM Reply With Quote
A supercharged R32, I bet that is nippy?!?
I will be reading this with interest, I am still undecided how best to run a SC. A BOV seems to be the best route, no recirc.
Please read my ring story:
theduck
posted on 31/3/15 at 09:49 PM Reply With Quote
Shamelessly stolen from
http://locostbuilders.co.uk/viewthread.php?tid=195525&page=4
dubzter
posted on 31/3/15 at 11:06 PM Reply With Quote
It's not bad, it's low pressure and makes around 5.5psi. It made 317bhp on the rollers (estimated flywheel). She is still a big nose heavy car but good fun and a great noise.
I'm really tempted to go the SC route once I get the car built and IVAd. Really like the progressive power delivery a SC gives.
Blog
luke2152
posted on 1/4/15 at 07:22 AM Reply With Quote
With MAP based fueling it should make no difference whether you use bov or recirc.
jeffw
posted on 1/4/15 at 08:26 AM Reply With Quote
I've used both a recirc valve (VAG 710N from the plenum to the inlet) and a valve which dumps to atmosphere. The recirc valve works but tends to raise the inlet temperature.
rdodger
posted on 1/4/15 at 10:32 AM Reply With Quote
Originally posted by jeffw
I've used both a recirc valve (VAG 710N from the plenum to the inlet) and a valve which dumps to atmosphere. The recirc valve works but tends to raise the inlet temperature. [/quote
Hi Jeff
My set up will be similar to yours.
Does your valve dump at idle?
jeffw
posted on 1/4/15 at 11:16 AM Reply With Quote
Yes, you can here the blow off at idle
rdodger
posted on 1/4/15 at 04:57 PM Reply With Quote
Great thanks!
jeffw
posted on 1/4/15 at 05:13 PM Reply With Quote
hear, not here of course. Dangers of replying on a phone !
New Topic New Reply
