Author: Subject: Easy injection return line solution available?
carpmart
posted on 15/6/15 at 09:47 AM Reply With Quote
Chaps
I'm likely moving from a carbed set-up to a fuel injected one, which in itself is not that earth shattering....
My question relates to fitting a return fuel line to the tank. I seem to recall there was a drill and fit attachment but I'm struggling to find it? Anyone know where I could get one of these, or indeed if they actually exists?
Thanks!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
40inches
posted on 15/6/15 at 09:55 AM Reply With Quote
It's for light Aircraft fuel tanks.
This one.
[Edited on 15-6-15 by 40inches]
carpmart
posted on 15/6/15 at 09:57 AM Reply With Quote
Cool, I will try another search.... Do you have a fixing name or brand to help me?
'94 MX5 MK1, 1.8
40inches
posted on 15/6/15 at 10:00 AM Reply With Quote
http://www.parts4aircraft.com/fuel-tank-fitting-c2x9383165
40inches
posted on 15/6/15 at 10:02 AM Reply With Quote
I'm going to use the vent connection for the return, and use the push in connector for the vent
carpmart
posted on 15/6/15 at 10:04 AM Reply With Quote
Looks just the job that, thanks for your help!
'94 MX5 MK1, 1.8
ReMan
posted on 15/6/15 at 10:12 AM Reply With Quote
Noted with interest, just the job for what you need
I cant believe that that is acceptable for aircraft though!
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
40inches
posted on 15/6/15 at 10:29 AM Reply With Quote
"can be used top and bottom of the fuel tank, for a sight tube"
motorcycle_mayhem
posted on 15/6/15 at 10:51 AM Reply With Quote
My only concern would be that aircraft don't tend to use alcoholic fuels, but those fittings have just got to be a good quality nitrile if they're used on aircraft.
The alternative to a fuel return line to the tank would be a dead head affair, just route the regulator spill to the fuel pump feed line.
posted on 15/6/15 at 11:57 AM Reply With Quote
Have a look at Car Builders Solutions , they list them I'm sure.
theconrodkid
posted on 15/6/15 at 07:33 PM Reply With Quote
i had one of them,worked well as afaik small aircraft use just normal petrol anyhow ?,one tip,when you drill the tank,assuming it,s ally,de-burr the inside of the hole or it cuts the rubber bung.
who cares who wins
pass the pork pies
